2006 f250 long crank
04-10-2015, 08:14 PM
on
Been gone from the forum awhile. How's everyone doing? Anyway I have an 06 that has a long crank first thing even after sitting for 30 min. Ficm is good, batteries are good. It is fuel related. Fuel bowl drains back down after a few min. No external leaks that I can see. Changed regulator and check valve. Thinking maybe pump is letting it leak back down. What's your thoughts??
04-10-2015, 08:38 PM
Hope you've been well.
Does the upper filter housing fill up fast?
04-10-2015, 08:41 PM
on
Yea it fills up fast. Just drains back down. Yea I am cool. Just a lot of stuff going on.
04-10-2015, 08:46 PM
Sounds like it must be the pump. You have a fuel pressure gauge?
04-10-2015, 08:49 PM
on
Yea has good pressure. Kind of stumping me. Thought maybe something in the pump letting it bleed back. But thought I would ask for suggestions.
04-10-2015, 09:34 PM
Hello Eric long time Bud
, Tried the Bubble test? I'm working on a few Hours sleep deprivation so the O'l brain is slow
04-10-2015, 09:36 PM
on
Yea did the bubble test. Passed. How are you doing?
04-10-2015, 09:40 PM
Doing good lot's O work . drain the water sep and got the right filters in there?
04-10-2015, 09:41 PM
on
04-10-2015, 09:44 PM
well Might have to put air test to the Menu don't think it's fuel , st fitting branch tube Injector , crap now my Brain is starting to wake up
04-10-2015, 09:46 PM
on
Lol. Might as well wake up before you need to get to sleep. Pretty sure it's fuel related. Fuel bowl shouldn't be draining back down.
04-11-2015, 09:50 PM
Working a Night shift , What did you come up with ?
04-11-2015, 10:13 PM
on
I haven't had time to work on it. Had to finish painting my dad's f150 and put the 05 font end on the 03 excursion.
04-12-2015, 12:29 PM
Nice looking Ride is that Part of the Fleet.
04-13-2015, 07:36 AM
on
Lol. Yea I guess. Only have a 06 and this 03 right now. Only has 90k miles. Plan on getting a 04 with 44k miles and a 05 KR with 110k miles this week. By the way it was the hpop reservoir leaking down on the long crank. Plan on fixing it today.
