mouse chewed up engine bay
So I went out to start the expy today and it was runing real rough and shaking alot barely wanted to run, so I popped the hood and found a nest made of grass on the passenger side of the intake manifold. Theres a vacuum line that hooks to the intake manifold that got chewed up along with a ground strap on firewall, the wire that hooks to the 4th coil, and the washer hose for the hood. The more I look for chewed up stuff the more I find. Quite a few wires that go to the ecm are chewed up. Whats the easiest way to fix this, just start splicing new wire in or what? The expy has only been sitting since sunday night.
Use XTreme Tape to Replace Heat-Shrink Wrap
If the copper is damaged, then you have to cut out the bad parts and replace the wires. For these I'd slip on 2 pieces of heat shrink tubing, solder in the new wire, then shrink the tubing over both solder joints to make your repair watertight.
Theres a 3/8" nipple on passenger side of throttle body and I think there are three vacuum lines that run together (black, white, and red) and hook to that nipple. If so thats not how mine was hooked up before the rodent chewed everything up. Can anyone confirm that, it has the 5.4 in it.
cps
06-17-2012 02:33 PM
amexjoe
05-25-2012 11:47 AM
