Tomahawk's F100
Old 07-22-2016, 08:30 PM
Tomahawk's Avatar
Tomahawk
Tomahawk is offline
Sorry for the late reply guys, I started a little electronic project last night and before I knew it I had to hit the hay.
Originally Posted by Randle
I've always heard the prep work is 95% of the paint job, and I can sure believe it. Looking good Buddy.
I'm just doing the under side, I can't imagine how long it would take me to do all the body work.
Originally Posted by GaryKip
Nice patch work, of course its never just a flat spot that needs patch.
No kidding Gary, that's what I was thinking when I started making holes on the other side of the offset. I may have uttered some foul language too.
Originally Posted by 67nukeford
I feel your pain, Gavin! I'm sure I'll be doing some of that patching on my box also. Beautiful work, btw!
Thanks Pat. I hope you have a great vacation!
Originally Posted by Freightrain
Famous last words...............
99% of the truck is completely solid, the other 1% is cheese.
I don't get it......and it's not bad in the places that are typically bad on these trucks.
Originally Posted by Brian1971f100
Nice work patching up the Swiss Cheese. Things just take as long as they take to get them right. Looking good, keep up the good work.
Thank for the complement Brian!
Originally Posted by JEFFFAFA
Might have been a bummer Gavin but I'm just glad you found it now. The rust had advanced enough to rear it's ugly head easily. If you haven't already, you might smack around the channels with a body hammer to make sure there isn't anymore rust not quite ready to show up yet.
Good idea, I'll poke around a little more. When I power washed the bed I knew there was going to be trouble in that channel just by the amount of dirt and rust flakes I got out of it.
Originally Posted by SavageNFS
Nice work buddy
I wish I could get more done, but the daily chance of rain in my paint booth sucks.
  #347
Old 07-24-2016, 08:19 PM
Iowa Ford's Avatar
Iowa Ford
Iowa Ford is offline
Gavin, Steady as she goes
Keep it up.
  #348
Old 07-27-2016, 10:34 PM
Tomahawk's Avatar
Tomahawk
Tomahawk is offline
Keep it up.
Hey Tim, the progress is pretty slow right now.
I did manage to get the bottom of the bed painted.
Sorry about the quality of this pic, the camera lens fogged.
Don't laugh, it worked for all those hard to reach places.
Primed and 3 coats of 2K urethane.
Next up for paint will be inside of the cab floor.
  #349
Old 07-27-2016, 10:58 PM
Randle's Avatar
Randle
Randle is offline
That looks great as usual Gavin. Love the brush handle. As the old saying goes "Necessity is the mother of invention."
  #350
Old 07-28-2016, 04:07 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
That underside looks almost new! What a difference.
  #351
Old 07-28-2016, 06:30 AM
SavageNFS's Avatar
SavageNFS
SavageNFS is offline
Received 7,068 Likes on 2,217 Posts
Man what a difference! That looks fantastic. Nice job Gavin. That will hold up for a long time for sure.
  #352
Old 07-28-2016, 07:19 AM
Jigger2020's Avatar
Jigger2020
Jigger2020 is offline
Received 5,160 Likes on 1,689 Posts
what they said ^^^
  #353
Old 07-28-2016, 10:27 AM
67nukeford's Avatar
67nukeford
67nukeford is offline
Wow! What did you use to paint the underside, Gavin?
  #354
Old 07-28-2016, 11:25 AM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
6X. Looookin' Gooood.
(Randle beat me to the ol' saying.)
  #355
Old 07-28-2016, 11:39 AM
Freightrain's Avatar
Freightrain
Freightrain is offline
Wow, that turned out fantastic.
  #356
Old 07-28-2016, 11:07 PM
Tomahawk's Avatar
Tomahawk
Tomahawk is offline
Originally Posted by GIGGER
what they said ^^^
Thanks for the complements guys! I was very lucky to have a bed that was already in good shape to start with. Getting between the inner and outer bed sides took almost 3 hours to put on two primer coats and then top coats all with the brush.
Pat - I used CRC Rust Converter as the primer and Speedokote satin black urethane for the top coat. So far the air dryer is working great! Good call!
Randle - The DeKups worked flawlessly, I had the paint gun upside down getting the back side of the channels and in between the bed sides as much as I could.
  #357
Old 08-09-2016, 08:23 PM
Tomahawk's Avatar
Tomahawk
Tomahawk is offline
Quick update....
I disassembled the front clip, holy cow that's a lot of 5/16-18 bolts.
The inners look good except for where the battery sits.
I did a lot more tack welds and I have to finish grinding the welds.
The passenger side mount on the core support had some rot, the drivers side is in great shape.
I drilled all the spot welds and removed the support plate.
The tab on the angle brace was almost completely rotted off.
I just need to fill all of the holes.
The neighbors auger wagon need a little TLC last night.
  #358
Old 08-09-2016, 08:35 PM
Randle's Avatar
Randle
Randle is offline
Looks like you are setting the standards high around here on patch panels. Good job. Done moved into the BIG time on the wagon.
  #359
Old 08-09-2016, 08:45 PM
SavageNFS's Avatar
SavageNFS
Nice work Gavin! Those look fantastic
  #360
Old 08-10-2016, 06:54 AM
67nukeford's Avatar
67nukeford
Nice fab work, Gavin!!
Quick Reply: Tomahawk's F100
