using studs instead of bolts for exhaust manifold
I'm getting ready to do an engine swap for a 351M. Someone suggested to use studs and nuts instead of bolts where the manifold bolts to the head. I was just going to find a local supplier and get threaded rod or individual studs. Should I just ask for grade 8 or is there something stronger? Also can I just use loc-tite when installing them? Of course I plan on tapping the holes to make sure they're clean. I'm sure I can check my manual for the thread spacing and so forth.
Do not use all thread. Get actual exhaust studs for your engine. I bought 2 packs of Ford exhaust manifold studs and they were not long enough on the head side. You don't want to use loc-tite at all on exhaust studs, unless it is there brand of anti seize. Here are reasons. The studs need to thread into the head a certain amount, this is what gives it the proper holding strength. A stud will have the part where the threads stop, this gives a place to tighten down too so as to not break through on the other side into a water passage or something. A stud made for exhaust will have all the proper treatments for being heated and cooled over and over again. Thread locker will make it so you will have no choice but to drill out the studs if you ever have to remove them.
jagrote
23
10-12-2016 12:20 AM
scottddove
11-09-2007 09:59 PM
PHOTOG101
04-22-2005 03:59 PM
