Vermont April 2015 BS - don't eat the chocolate jelly beans left by the Easter Bunny
#1113
Don on your steering issue when it acts up, if you pull over and shut it off, then restart and drive is it ok? they have an upgraded steering resiviour for the truck, I had to put a couple in, they added a filter inside the plastic housing to prevent dirt from sticking in the pump and box. works great. easy to do, just tell ford you want the updated steering res.
Is that upgrade for the 2006 model year or earlier?? Mine is an 06
#1114
on
Actually they did it in all the 2010 and up, there is no TSB on it but they do have a ford service listing it as a sticky steering. Yes it does go away by itself too but a quick way to tell is to shut it off and start it back up, if it goes away, put the updated resivour in it, you can compare the two side by side, it's just a cotton filter down the hole, when you look down it, we have had the problem on several of our trucks and I put the updated resi on all the trucks and have never had the problem come back. It's dirt sticking in the pump and box causing the hard steering. Ford knows about it but I think there afraid to have a recall that sounds like that!! Lose of steering while traveling 60 MPH on the thruway, you know. But I bet ya if you get a new resivour it will have a filter in it, not just a plastic bottle.
#1116
Sounds like a cheaper fix than Replacing the steering box
#1117
Received 5,160 Likes
on
#1118
on
I learned the hard way, pump and than the box. Then a friend at my local Ford dealership told me on the down low. It's scary when it happens, right? you can still steer but the wheel wont return and sometimes it's like manual steering all over again.
#1120
on
#1121
I was thinking it felt like a stuck hydraulic valve and was thinking of draining all the fluid thinking there was crap in there..
Do you buy a specific reservoir or are they all modified now???
#1123
on
#1124
Good evening woodchucks. Been so busy I forgot to check in. Been a blah day weather wise. But I got the battery into the motorcycle and I plan to ride to a board meeting in Burlington tomorrow unless it is pouring.
Helped Helen out with foster dogs today - she got one placed and took in one more and has that one placed as of the end of the week. I got to drive her around to deliver dogs with the truck since her car was in getting new rotors and pads on the rear. But it works a lot better when there are pads in the calipers. She was down to metal. Rotors were shot anyway - 60,000 miles on the rears is pretty decent if you ask me. Wasn't much left of the rotors.
Off to bed and gone all day tomorrow. Have a good one guys.
