Today is the day........
#76
I agree that the Sailun are great and have recommended them to people who don't want to spend on the GY's. However, as other's mentioned, they warranty on the GY's is outstanding on both the tires and trailer damaged caused by them in a blowout. That alone is worth the upcharge. I can get 6 mounted and balanced for $325 per at my local shop so off I go later this week. Will be installing solid bolt in metal stems while there too to keep my TPMS from flapping in the breeze. Did the same routine on the last rig and was a perfect worry free setup.
#78
Couple reasons. First is the aforementioned Goodyear warranty for the G614's. The second is probably silly but I just don't like putting 6k worth of tires on 7k axles on a 21k GVWR vehicle. Yes, 3k will always be on the pin, but I still like the extra #...
#79
Received 4,005 Likes
on
What is the Pin Weight ???
Mine is 4,350lbs. Nothing heavy stored up front.
#80
on
Roy, If you take a look at most other fivers the same length as yours, you'll see that the Toy Hauler axles are just a little further back than the normal fiver.. This puts a forward weight bias on the trailer to make up for the weight they are built to carry in the garage. Since you don't carry heavy toys, just a bedroom back there, your pin weight is going to be higher.. Hopefully not higher than the chassis is rated for...
#81
on
I have absolutely NO DOUBT that the Gy614 is a great tire and is worlds better than the Marathons... Problem is that the money would go to GY and since they have refused to support their other tires to **ANY** degree, I am loth to put one single red cent more into their pockets.. Forever.
Also talking with some friends in other states, I run the risk of legal problems, especially if I get in a serious accident.
The Dually eliminated all those concerns.........
#82
If your 5er weighs 21k (biggun!) doesn't that mean the manufacturer would have to provide the proper number and capacity axles to handle it? If they're 7k axles and you've got 3 of them, is that where the GVWR comes from? Does it actually weigh that? If it does, man, they're putting you in a bad place.
#83
Roy, my loaded pin should be about 3-3100. This is what it was on my last one and that one had the same unloaded pin weight as this one. So, I'm assuming they will be the same loaded as well.
Randy, yes, they don't back the Marathon line. They do however back the G614's and while I appreciate that you are upset that they didn't back your tires, it's apples and oranges on the 614's I'm after which they always back.
Firekite: The trailers GVWR is 21k. The trailer has three 7k axles. Ribs are rated at 3040 each so, two per axle only nets 6080 worth of rating on a 7k axle which I don't like. Right now, without gear or toys in the garage, it weighs about 16k. No, it likely won't be at 21k when I load it up with the gear/toys I will bring. 21k is the GVWR which is the max it can legally and safely weigh. As to putting me in a bad place, I have no idea what you're talking about.
#84
#85
No, both the LR E ST tires that came on the trailer as well as GY G614's are rated at 3750 each so they match the 7k axles perfectly with # to spare.
#87
#88
#89
A little extra capacity never hurt anyone. Some guys buy gasser engines too for hauling this kind of load. I went with a 6.7....
#90
