I'm looking for bell housing, fly wheel, granny four speed with bolt on 205 transfer. It's going in a 1976 3/4 ton. The truck is a 3/4 ton shortened with a step side with 6 in. Lift.
flywheel with a clutch assymbly for a 360/390 is what you need. 351M/400 bell housing will work on a 460. you will also need the clucth linkage and brackets as well as the pedel assymbly. new throw outbearing too.
