So you just bought an Excursion and have the dumbest question ever? Ask it here!
on
Here are two random questions I thought about in my head.... but never really thought about asking
1) this winter we got a lot of snow so I tended to leave my hubs locked (clock to lock)... but now that its spring those suckers seem stuck in place and I cant get them unlocked (counter clockwise)..... any tips or suggestions ??
2) other than gas mileage - does it hurt anything letting them in the locked position going down the highway in 2 wheel drive for extended periods of time ??
It is a failsafe to lock them when your vac system fails. Rangers used a similar pulse hub design for a few years but didn't get the benefit of a manual override...a lot of them are modded to be manually engaged. On the f250's and up, auto hubs were an option and the manual hubs look the same with the exception of having "free" instead of "auto"
I sorta thought that it worked like a ratchet so to speak. When back wheels started slipping the drive unit would be all spinning faster than front wheels and the axles would engage the wheels. When all else was equal then there was no drive applied to front wheels.
Nope, its a traditional 4wd. No a ratcheting auto style. Auto on the hubs simply means that you shouldn't have to get out and lock the hubs when you turn the dial to 4wd. All excursions came with auto hubs. The vac line feeds into the back of the knuckle towards the top and relies on the seals in the knuckle and hub, and the reason they get changed to manual hubs a lot.
Here are my pre-purchase questions:
1. Does crap build up in the coolant resevoir? The truck in question is a 2000 5.4 Ex, runs fine, pulls fine, but there's goop in the coolant can, didn't hear anything that sounded like a blown head though..
2. The little console thing on the ceiling, is there a good way to figure out why it doesn't work, or is there something more productive I can swap in there.
3. When I turned the steering wheel, the truck made a noise, like a moan .. could the steering box be going?
Thanks
Thanks
#28
Thanks
Thanks
If you push real hard on the buttons will it come on momentarily?
This was a common problem on explorers and I cannot see Ford doing anything radically different on the Ex.
If you take it apart ( easy ) you will find a surface mounted resistor on circuit board that has broken free of it's solder joint.
Very easy fix.
#29
