6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4 developed a knock. Thoughts?
Old 03-27-2015, 11:02 PM
CKetchum's Avatar
CKetchum
CKetchum is offline
Originally Posted by parkland
Lots, they are keystone rings designed to seal up with higher pressures.
At idle, lots of blowby, under hard boost and fueling, they should seal up better than normal rings.
But in general, lots of blowby.
From what I gather, normal rings would have less blowby at idle, but wouldn't work as good holding pressure at high boost.
Didn't know that aspect about the rings...learn something new everyday! Thanks for the info!
Old 03-28-2015, 06:08 AM
78fordman's Avatar
78fordman
78fordman is offline
Don't even go off on an oil weight tangent you *******.
Hate it when you end up arguing with your self. Lol
Old 03-28-2015, 10:56 AM
FishOnOne's Avatar
FishOnOne
FishOnOne is offline
Received 1,447 Likes on 893 Posts
There's a video on this topic at around 3:50 you can see the cost cutting measure's from Navistar. I've heard this ringing/tapping noise a believe it to be the issue covered in this video.
Good luck...
Old 04-03-2015, 08:19 PM
Hunter40's Avatar
Hunter40
Hunter40 is offline
I took the truck to the Ford dealer today. I will keep you posted as to what they find out. Interestingly when I first started it the noise was not there, but by the time I made it to the shop it was tapping again. It seems to be more prevalent when warm, similar to the symptoms Tepot is having in another thread.
Hunter40
Old 04-06-2015, 06:44 PM
Hunter40's Avatar
Hunter40
Hunter40 is offline
Just a quick update on the problem. Tech is still trying to determine the problem. Today he found the fuel trim level high on cylinder 2 at 18. The rest were okay. Power balance test showed variances on cylinders 2,6, and 8 of -1,-1,and -2 respectively. Definitely something going on with that bank.
Since the balance test was not that far off I am hoping for just an injector, but I am usually not that lucky.
Next step is to pull driver side valve cover to inspect valve train and perform a manual compression test.
Hunter40
Old 04-07-2015, 05:21 AM
senix's Avatar
senix
senix is offline
Received 1,417 Likes on 1,012 Posts
Rocker arms...be sure to do both sides.
Old 04-07-2015, 05:49 PM
Hunter40's Avatar
Hunter40
Hunter40 is offline
Good call Senix. Rockers are "severely worn" and need replacement. Tech was unable to get a good view of cylinder 2 with a bore scope, but service manager was not sure why.
Compression test in the morning to check condition of cylinders.
Hunter40
Old 04-07-2015, 06:28 PM
senix's Avatar
senix
senix is offline
6.4 suffers from top end lubrication. Often oil changes (5K) will help but they still wear fast.
I would replace them all and put it back together.
Old 04-07-2015, 07:02 PM
Hunter40's Avatar
Hunter40
Hunter40 is offline
Thanks Senix- That is the plan if the compression checks okay. Just hoping there is not any other damage.
Oil has been changed every 5,000 with T6 Rotella. The truck never idles and averages 43mph over its life. This just points to a poor design by Navistar in my opinion.
Hunter40
Old 04-07-2015, 07:05 PM
senix's Avatar
senix
senix is offline
My bet will be the compression will not check out that well because of the rocker arms.
Old 04-08-2015, 06:33 PM
Hunter40's Avatar
Hunter40
Hunter40 is offline
It's almost like you are working on my truck, Senix.
Compression was a little low in all cylinders. #2 was the worst at 250. However upon more inspection the tech found that the injector was hanging open and slightly scored the top of the piston. The #8 cylinder cross hatches are getting worn off too.
The tech recommends a complete engine to repir ti right but thought it would run for a while with just the new injector and rockers. Since I don't have $18,500 lying around for a new engine, that is the route I am planning to go.
Is this a good idea with thise compressions? I'm guessing the compressions will get better after new rockers. Should I address anything else with either cylinder 2 or 8?
Old 04-08-2015, 06:37 PM
senix's Avatar
senix
senix is offline
My arm chair recommendations are just that..New rockers, new injector, change the oil, have them recheck the injectors with IDS.
Drive and enjoy the truck.
  #28
Old 04-09-2015, 01:03 AM
SANDDEMON08's Avatar
SANDDEMON08
SANDDEMON08 is offline
The only thing i would add to that is the valve bridges, if the rockers where severely worn they almost always damage the valve bridges, there cheap and should be replaced while your in there.
  #29
Old 04-09-2015, 07:06 AM
CKetchum's Avatar
CKetchum
CKetchum is offline
If you don't mind me being nosey, how much are they charging to replace the rockers, bridges, and the one injector? Hope it goes well for you!
Clint
  #30
Old 04-09-2015, 09:40 AM
Hunter40's Avatar
Hunter40
Hunter40 is offline
Clint
I was quoted $4500 for the rockers and one injector, and $18,500 for a new engine.
Hunter40
Quick Reply: 6.4 developed a knock. Thoughts?
