Lees build - repair - negleted maintenance finds - pic heavy
Old 12-30-2015, 12:15 PM
lee00's Avatar
lee00
lee00 is offline
Originally Posted by oldbird1965
Ok Glenn since we are trashing this thread....How about shedding your opinion on my thoughts below? (seeing as you are what I would consider a camping god with all the time you spend on the road!)
I am really thinking I need to get to RRE again this year.... so I have started looking at campers online...
Things I know:
1. More than likely going used...really don't have the funds for new unless I get a hell of a deal!
2. Looking to stay under $10,000
3. Bunkhouses - the girlfriends pesky 3 kids dictates this necessity
3a. - need one where the bunk hous eis seperable - ei curtain or door.
4. I figure 27'+ (based on my other demands looking to be 30-37')
5. I don't want to have to walk through the bathroom to get to either the bunks or the master bedroom
6. Prefer Travel trailer over 5th - would like to keep bed space for bicycles and like gear.
What am I missing and do you have any suggestions? (I know finish the truck first!)
  #242
Old 12-30-2015, 08:52 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
haha, I'm not the camping God, that's for sure! I have always bought used, the price of new ones are crazy. I hope your girlfriend is like my wife, patience! This last 5er we looked for it for three years. When you see 'the one' you will know it. Look for the little things to see if it was well used, they are all full of problems so try to keep it to a minimum. I never wanted a pull trailer but I can see your point in wanting one. Most of the bunk houses have a door on them, that I've seen anyway. If you get a toy hauler you can make them a bedroom in the back and carry your toys. I don't like those walk thru bathroom either. The bigger the axles and tires the better. Look at the bottom if its covered to see if its been cut open to fix stuff. If possible operate the slides to see if they work OK. Important, look at the ceiling for water stains and look at the roof to see how good the condition is.
Good luck, my wife drove me crazy looking. I saw a lot of them I wanted to buy but I'm glad she held me back. We found one in excellent shape that wasn't used much and stored indoors. Also, a very good price compared to ebay, rvtrader, craig's list, etc. These are good spots to get a good idea of what they are worth. I never did like dealers, they like to stab you in the back.
  #243
Old 03-10-2016, 03:15 PM
lee00's Avatar
lee00
lee00 is offline
bumping this back up the list as I will be back to working on the truck in 8 days...
  #244
Old 03-10-2016, 07:08 PM
sean9049's Avatar
sean9049
sean9049 is offline
Whats the plan, Lee?
  #245
Old 03-10-2016, 07:49 PM
fordman67's Avatar
fordman67
fordman67 is offline
Ssaawweett!!yi Git daquoycvbnmhyuu
Well then (3year old typing)^^^
On campers study!! Look,shop and learn. I never knew SO many configurations of the same model were available. Slide is good and super slides add to the price but are huge once slid out. I had a sunny Brooke I wanted bad.. The ss was epic and it was huge when out. Just all about budget here!!
  #246
Old 03-11-2016, 06:45 AM
lee00's Avatar
lee00
lee00 is offline
I think the camper is on hold until I get my tax bills paid off...
  #247
Old 03-11-2016, 06:51 AM
lee00's Avatar
lee00
lee00 is offline
The plan for this weekend....(on the truck)
Drop tranny off at rebuilder...
Finish deleting ebpv
reinstall rebuilt and deleted turbo
Install rebuilt injectors
install new oil pan - buy and install new IH dip stick tube adapter
Set engine in engine bay....
cut up gas core support
re weld gas core support to mirror diesel one...
work on getting gauges installed...
On my car - (200,000 miles service)
Find exhaust leak (maybe repair)
spark plugs
oil change
tranny fluid change
new rear drums (possible bearing failure)?
rotate tires
  #248
Old 03-11-2016, 07:05 AM
lee00's Avatar
lee00
lee00 is offline
spark plugs
oil change
tranny fluid change
rotate tires
I forgot to mention picking up an 01-02 explorer this weekend.
  #249
Old 03-17-2016, 12:26 PM
lee00's Avatar
lee00
lee00 is offline
Dang down to page three in a week! Picked up the IH dipstick adapter repair kit... $87 and change after taxes....
Should have just bit the bullet and bought the gold nugget!
Upside is I have enough red Loctite and gasket sealant to kill an elephant...
  #250
Old 03-17-2016, 04:28 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
You got a heck of a list of plans for the weekend Lee! Good luck knocking a chunck of that off!
  #251
Old 03-21-2016, 10:03 AM
lee00's Avatar
lee00
lee00 is offline
spark plugs
oil change
tranny fluid change
rotate tires
Not surprising I didn't get much done on the truck...
All I finished on the truck was:
Install rebuilt injectors - done
install new oil galley end plugs - done
install fuel rail banjo bolt orings - done
install riff raff plenum boots - done
clean plenum Y - done
clean uvch - done
clean uvch - head mating surfaces - done
clean uvch - valve cover mating surface - done
knock off rust and prime frame horns - done
blow dirt out of valley - done
On the car I finished -
Find and replace exhaust leak - flex pipe - done
spark plugs - done
oil change -done
tranny fluid change- done
new rear drums - done
new rear brake shoes - done
rotate tires - done
Pictures to follow this afternoon...
  #252
Old 03-21-2016, 10:48 AM
Minnesota_Duane's Avatar
Minnesota_Duane
Minnesota_Duane is offline
Ebay also....
Some how it has a built in running light too...
let me find the link...
$40... listing is gone.... but here is the description
92-96 FORD F150 F250 F350 SMOKE LED THIRD 3RD BRAKE LIGHT STOP LAMP
looks like this one
92 96 Ford F150 F250 F350 Clear LED Third 3rd Brake Light Stop Lamp | eBay
Any negative effects from using this IE dropping out of lockup shutting off the cruise? I had a bulb out in mine and was doing all sorts of strange things, I'm just wondering if the low amp draw LEDs cause any ill effects?
  #253
Old 03-21-2016, 10:54 AM
lee00's Avatar
lee00
lee00 is offline
Cant really answer that at this point...trucks been in rehab for the last year... still working on putting it back together... once I get it done I will update... probably going to be another couple of months though
  #254
Old 03-21-2016, 11:03 AM
Minnesota_Duane
Please do I'm interested in one of these lights as mine have some bulb sockets that have been pretty hot.
  #255
Old 03-21-2016, 08:54 PM
sean9049's Avatar
sean9049
sean9049 is offline
just bought it, will update once installed(march 29 eta)
Quick Reply: Lees build - repair - negleted maintenance finds - pic heavy
