intake fitting 1999 Ford F-150
Old 03-17-2015, 06:33 PM
DrivingFords's Avatar
DrivingFords
DrivingFords is offline
Bought an old truck and it was leaking coolant. It was leaking around a fitting that screws into the intake. Called our local Ford dealership and said that they no longer make that part. The man at Ford referred to it as an "elbow" Any idea about where I can get the part without replacing the entire intake.
Old 03-17-2015, 07:44 PM
kd4gij's Avatar
kd4gij
kd4gij is offline
What motor? Take a pic the part if you can.
Old 03-17-2015, 11:12 PM
k.rags's Avatar
k.rags
k.rags is offline
Elbow at back of intake?
I have 1997 F150 4.6L and had a leak on the tube (elbow?) that attaches to back of manifold and it was leaking. I cut off the the tube flush, drilled out hole to 3/4" and tapped it for a 1/2" pipe thread. I then attached a short piece of copper pipe with soldered 1/2" threaded coupling. I then soldered on an elbow, short pipe, and hose fitting. Took a couple of hours.
bro460
Modular V10 (6.8l)
07-21-2013 07:46 AM
sleepinghound
1997 - 2003 F150
04-03-2012 07:14 AM
2pd519
1997 - 2003 F150
08-18-2011 07:52 PM
DaMan28n88
3.8 & 4.2L V6
11-03-2007 11:12 PM
magoo50
3.8 & 4.2L V6
02-23-2007 11:37 AM
Quick Reply: intake fitting 1999 Ford F-150
