Flat head intake manifold is extremely hot!
So i got my 51 out today and drove about 10 miles and when i came home i decided to get out the Non contact temp gauge and was taking readings from all over the engine and when i put it on the intake manifold just below the carb, it showed over 300 degrees! I checked both side and they were the same. I don't think that is how its supposed to be. Any ideas Why?
Hot Flathead
The heating exhaust passages in the V8's are about the size of a penny. Hot-rodders in the '50's used to put pennies in the holes to block them, it is surprising how much it changes the exhaust note! (makes it crackle)
I tried running with SS shims over the passages, with 1/4" holes drilled in them, to reduce the amount of heating, but not eliminate it. Even in mild (70 deg) weather the engine took 5 minutes on the road to eliminate bogging, it was just too cold. I pulled the shims out after a couple weeks. Put your hand on the back of the carb after a cold start, you'll be surprised how cold it gets! I saw frost once.
pw700z
04-07-2018 02:45 PM
wl_keller
04-14-2002 11:29 PM
