01 sport trac won't start
Keep in mind that WOT also shuts off the fuel injectors and is also known as "Clear flood" mode, which is I am curious how the spark plugs look. If they show signs of being fouled already (since they are new) or are wet with fuel, that could suggest either too much fuel or the fuel that is getting to them doesn't want to burn.
But your comment about air flow got me wondering if there's a chance you have a restricted exhaust (more common than restricted intake) which might help explain the no start as well. to check for an exhaust restriction, one thing you could try is to remove both pre-converter oxygen sensors. The small holes from the sensors won't be enough to support full throttle if the exhaust is plugged, but they should allow enough exhaust to escape for the engine to start in such a scenario. And if the intake is plugged you could identify that as well as a lack of air coming out the holes when the starter is spinning the engine over. I guess a compression test would help identify that as well though too.
Hmm, maybe the compression test would be the easier place to start.... Or if you happen to have access to a cylinder leakdown tester you could test both scenarios just by removing the spark plugs, installing the leakdown tester, and slowly turning the engine over by hand and listening for where the air escapes (throttle body when intake valves are open, tail pipe when exhaust valves are open).
-Rod
-Rod
RL250
10-03-2016 11:55 PM
leadfoot7
08-23-2012 03:49 PM
simmonds1970
15
02-24-2012 10:44 PM
Explorer180
03-15-2011 10:32 PM
brian fitz
1997-2006 Expedition & Navigator
17
05-16-2010 07:14 AM
