2011 F250 w/6.7 ??
Print your list so you don't forget to have a look. Ask for an OASIS from the service advisor. Have the salesperson walk over there with you. That will give you warranty info.
Check the **** on the door again for the mirrors. I may just be in the center position. Have them fix it!
will do..
The only real problems I found were..
Power mirror on drivers side won't adjust, but it does telescope out - I agree with Scott, but a dealer should fix if broken
I didn't think to the check mirror heat.. - Not a deal killer IMO
Forgot to check for a block heater - If originally sold in the North, it's standard and the lead may be tucked in the bottom RHS grill opening
Never got an answer on remaining warranty (we got side tracked BS'ing I guess) - OOPS!! been there as well, but like I said, consider that ESP
Forgot to ask about TSB's and updates - OASIS will tell you, but there should only be a couple, horsepower and torque upgrade if an early truck and the latest emissions 14E03
No bed liner the bed was scuffed up pretty good not dented or damaged - Would not be a deal killer for me. You can do a home bed liner application for less then a hundred bucks if you feel the need to cover the scuffs
The interior could use a good scrub'n it was a little dirty but not damaged - any reputable dealer should do a detailing as you will be advertising his sale. Mine did a great one including a small 'paintless dent repair' on the tailgate
Sounds like you have a decent truck to consider if you can get a couple things cleaned up and the price is right. As far as how these 6.7's run, they are amazingly quick - I blew off a big size Honda up to 65 mph (NY speed limit) getting on I-87 a couple days ago.
We are close to getting this done..
If you don't mind driving 175 miles, Carmody Ford in Greenwich usually has some good ones on the lot and where my last two came from
