Noisy front leaf springs - brand new ATS
#46
#47
I haven't looked in a few weeks, so your saying this bracket can come off and use washers to drop it down some? That sounds like a possible fix. I do not see the springs driving themselves back to center. Mine were centered when installed and pulled over to the side after a few hundred miles. Fixing the trac bar and then massaging them back would be my guess.
#48
#49
I still have not solved my front end noise. While I believe it is somewhat different than the others who have posted in the this thread, I will update once I can get it solved.
I have an adjustable front trackbar on order and will install once it arrives. I also installed 1" lift shackles on the front springs as the 2" rake was bugging me.
I have also developed a noise from the rear, but this one I believe I know the cause. ATS does not use isolators when they build the C code with the added leaf. I will have to add something to get rid of the noise.
#50
But before you do any noise prevention, I'd get the truck on a lift that allows the axle to hang down (stretch out the springs) and look for shiny spots, if it's been squeaking, you'll see wear.
#51
#53
After installing the front lift shackles the front became much noisier than before. It took lots of effort to get the spring aligned and I am sure that the axle is getting pulled to the driver side due to the factory track bar. Once the new one goes on I expect improvements. It may not solve everything but it should help...
#54
#55
#56
Just put my head under the truck to check mine. I used ford springs & the over loads from the rear B pack (LIKE TOM's rig). The total lift was 3 1/8" to 3 1/4". The picture you posted 05Mill was fairly disturbing & easy to tell why you had noise. The factory spring bushing EXtends far enough past the spring eye so as not to allow the spring eye to make contact with the spring cup as your picture shows. I don't know if my track bar is in a bine BUT I don't have any noise , metal on metal contact anywhere, & the truck drives great, straight and true
#57
#58
I'm going to check more closely today for you as well as the old X's I just looked at my old X spring. On the front spring eye the steel sleeve in the bushing is almost 1/4" longer on each side of the spring. Not very much, BUT when installed it does look like it is keeping the spring from hitting the inside of the mounting pocket. If your spring's bushing are flush it looks like a few well placed washers would do the trick......
#59
Finally got the adjustable track bar on. The axle is centered almost perfect. The drivers side spring came back to center, but the front of the passenger side spring is still pulled against and rubbing on the hanger. Out of solutions! I think the rubber that is used in these aftermarket springs are not the quality that Ford uses. Thinking about ordering a 3 inch hanger kit and putting the stock springs back on.
#60
