2000 f350 leveling lift
Hey guys i need some help with a problem that i am running into. I have a 2000 f350 powerstroke and i just bought a 3" leveling kit and a set or 18" wheels (8.5) for it and was hoping to get a set of 35 12.50s on it but was wondering if anyone knows if it would rub? I am having a hard time finding any answers. Some ppl say it will be okay and others say it will rub. Any help would be greatly appreciated. Thanks
on
1 Post
Yep most likely had 33s on stock offset and they rubbed . Maybe if you stick the tires outside the fenders they won't rub. Other problem is May rub fender as they aren't as open as the new trucks .. My 33s rubbed on the leaf springs and if the front wheel was turned while the suspension was extended because of off camber or a bump the tire would rub the mud flap. Anything over 33" you better look into a bigger suspension lift. But that's my opinion and my truck had a 3" level kit and 4 inch blocks " 01 f 350"
Just put a 2.5" leveling kit on my 2003 f250 5.4 and 17x9 wheels with -12 offset with 315/70R17 and it rubbed on the plastic under the bumper. Just had to cut the corner off that for it to clear. But they also rub on the back side of the wheel well. I'm gonna try to zip tie that part back so it clears.
