Advice needed for a rookie 1950 Ford F2
#32
#33
Yes I see the holes in the fenders but either it was a special order or the dealer changed them.They have definitely been on there since the truck was new or next to new. There is no indication that there were any running boards attached to the rear fenders. Also the wear pattern from the road spray from the front tires is consistent on both sides. Imo. Anyways I didn't mean to Hijack this thread. Good catch Joe.
Left side
Right side.
Left side
Right side.
#34
#35
#36
#37
Any idea the size of this longbolts and flat washers? I dont have the parts disk yet and can't find anything on it.
#38
#39
#40
Before you spend even 1.00 or 1 hr's time on it, take the paperwork to your DMV and obtain a clear title in your name. The feds are pressing the states to tighten up their titling process and so the rules are getting more onerous by the day. Without a clear title that matches the serial # stamped on the frame, or a new serial # issued by your state you may never be able to resell it or license it for the street, or if the frame # comes up on a hot sheet somewhere the entire truck could be confiscated from you. Don't wait or try to circumvent the DMV's rules no matter what anyone tells you.
#42
Found out the truck will be here Tuesday. So hopefully my next post will be pictures. My last dilemma is storing. I originally thought it might fit in my father-in-laws garage (I am in the process of selling my house) but apparently it won't. As of now that leaves outside in the snow as my option. Since it's been in North Dakota, I'm sure its used to it. But is there anything I should do? Tarp, methods of keeping mice away, anything? Theres no windshield or back glass yet so not sure I should tarp it or leave it out. It won't be anywhere near the roads so salt won't be an issue. Any advice would be much appreciated and pics will come soon!
#43
#44
I know several of you were asking about the engine. I was able today to pull the spark plugs and try to turn the engine with a breaker bar. It does move. It took some muscle but by no means full force. I dont know if thats good or bad, but I thought id update everyone. Any takes on this would be nice. Good sign? Bad sign?
#45
With the spark plugs removed, you should be able to turn the engine over with slight resistance . Sounds like you may have a good engine. Not being locked up is a big plus. You could still have a valve or two stuck. Most of the time marvel mystery oil will free those up, depending on how long it has been sitting. These engines have been known to run quite well with all sorts of problems that are discovered after a tear down. If your engine is turning over, I would put fresh oil in it, check all of the electrical and try to fire it up. You don't need the generator or fan to fire it, but you won't be able to run it long if it starts. Don't let it run more than about 30 sec. With all of that said, as a young kid, I have seen a lot of vehicles parked and never ran again due to something as simple as the starter failing. I'm 66, and people junked cars or just quit driving them for a lot of reasons. You could buy a good running used car for $75. back then. Hope this helps. And good luck.
