P0174 issues
Old 02-21-2015, 11:07 PM
junior-f250's Avatar
junior-f250
junior-f250 is offline
P0174 issues
So im in search of some assistance. My 06 f250 has had bank 2 catalyst code ( p0430)and lean bank 2 code (p0174) only when i am trying to hard accelerate. It pops and jerks a little then takes off. So i hooked my scanner to it and found that the cat on bank 2 was bad watching pre and post cat o2 sensor readings. So i replaced the y pipe cat assembly And both downstream o2 sensors. I still get po174 on hard acceleration. If im light on it, it acts perfectly fine. Plugs were done a year ago along with one ignition coil.
Old 02-22-2015, 09:21 AM
JWA's Avatar
JWA
JWA is offline
Received 1,394 Likes on 1,103 Posts
Sounds like the typical cause of this DTC----vacuum leak most likely somewhere along the PCV valve plumbing.
Check at the base of the throttle body for the insulation-covered 90 degree elbow---they crack all too often. They're readily available from most any auto parts sellers, check with your local Advance Auto etc etc.
Old 02-22-2015, 10:51 AM
junior-f250
The only issue is that i have the 5.4 3 valve sohc motor so there is a hard line going from drivers side valve cover to intake with a quick disconnect. The pcv its self is an integral part of the drivers side valve cover. In other words its only serviceable by removing the valve cover.
Old 02-23-2015, 07:26 AM
JWA's Avatar
JWA
JWA is offline
Okay that may be---I'm not familiar with the 3V motors.
But can the connections or plumbing itself be inspected or tested to assure its not the issue?
g3ride69
03-24-2016 05:56 PM
AZ Elk Hunter
1997-2006 Expedition & Navigator
02-20-2011 08:06 PM
Argess
1983 - 2012 Ranger & B-Series
01-03-2011 12:24 AM
sprinklerguy
1997 - 2003 F150
03-27-2007 04:23 PM
tazzis37
07-11-2004 06:37 PM
Quick Reply: P0174 issues
