Budget is officially history!
#31
I keep a pretty tight budget. I have so far spent $19518 including paint. My goal was to keep it under $20k. So doing pretty good.
THe budget on my factory five roadster was $26k and I spent closer to $30k. SO I blew that one a little, but mostly on add ons and things I wanted to put in later.
It works for me to plan out everything ahead of time in as much detail as possible, probably bc I have been trained as a project manager for part of my employment.
I hear you on gauges though, they are one of the most expensive pieces I bought... paid $570 for new vintage gauges. They are pretty nice though.
#32
#33
That's not quite true, I have a golf bag full of clubs in the attic of my garage and some really nice white wing tip foot joy's hanging on the wall. They don't quite fit in with the old truck.
#34
#35
#36
I had a hobby once upon a time that cost about $10,000 a year. That was running bird dogs in field trials with a professional trainer/handler. I got one champion pointer out of 6 years of trials, or about $60,000. He was the 1984 Arizona Shooting Dog Champion. And of course, he's been dead for years. But I'll never forget him or the fun I had training and running bird dogs.
Trucks are cheaper and easier to work as a hobbyist. I am having fun with my first old truck. I am keeping track of the expense, but not because it is a limited amount due to a budget. It's recorded so I know what I spent, because I want to know.
#37
I play a little golf and it is a fairly expensive sport. What I really do a lot is playing tennis at local public courts (one is two houses down the street from mine). Tennis is cheap as rackets last a long time with just restringing and ***** are cheap too. It keeps me in good shape and probably helps keep my coordination and brain in better shape too as I keep getting older and older (can't seem to stop that). The truck on the other hand is a fairly expensive hobby, but very rewarding in other non-monetary ways. I think most of us realize that we will spend much more than the resale value of our trucks. IMO, so what? It is fun to build and that first drive makes it worth it!
#38
#39
#40
I should have documented the out of pocket cash with the latest build, but I have everything on excel. A safe reliable vehicle can be build for not much money but it does take work, which I consider fun.
#41
Tank send problem with my new gages.
It was 81 here yesterday and got a lot of work done on my 52 F1 but I will start paying for it today as it will get down to 33 tonight.
I went with Vintage USA gages with 12 volt and had problems fitting the fuel sending unit to the tank behind the seat. 5 hole to 6 hole and with an adaptor the unit would not go down through the hole.
If you run into this problem I have how I cured the problem on one of my posts.
TractormanBill
I tore the old unit down and used the flange for the new unit.
Brazed an disc in the the old flange.
Built a box the same size as the inside of the tank to help set float.
TractormanBill
#43
#44
Ern-Dawgie's 13 Step Budget Process:
Identify what you need
Have "budget-minded" intentions
Open the Summit website
Find the part you had in mind
Notice the high priced, ultra-bitchin version below your selection
Dismiss the possibility - Keep revisiting the page... (10 times)
Agonize that you want it but can't justify it
Sweep aside all logic and order the cooler part anyway
Experience intense guilt after hitting the "Submit Order" button
Listen impatiently for the UPS Truck
Do your "happy dance" when you open the box
Wait 2 weeks for the Wife to open the Visa Bill - Prepare your defense
Be grateful for a supportive Wife and glad you got the bitchin part...
