timing
Ummm well...do you have a timing light? If not you can aim for the highest vacuum if you have a gauge. If you don't have either of those you can aim for the highest idle rpm if you have a tach. If none of that will work just loosen the clamp and rotate it a little bit at a time, going for a test drive between each adjustment.
bhardy501
05-12-2007 07:33 PM
ceetwarrior
46
10-09-2004 08:43 PM
Ford79
19
09-12-2002 11:17 PM
