351w vs 351m/400 vs 460?
Old 02-07-2015, 01:20 PM
ponykilr's Avatar
ponykilr
ponykilr is offline
460. Same or better mileage as a 351 and more torque. Brutus gets 13+ even after the 37s. Easy bolt in, plentiful donor vehicles and keep EFI with no tuning issues you may have with a modded up 351. Plus, everyone has a small block F150....
  #32
Old 02-07-2015, 03:20 PM
BruteFord's Avatar
BruteFord
BruteFord is offline
Going diesel even the completely awesome IDI = just buy a different truck, swapping one into a F150 is pointless.
Idk what would make anyone say that 400 heads don't flow, Cleveland family engines of which the 400 is one are infamous for great heads. They have been the root of the vast majority of the infamous Ford performance engines. Yeah, you got to do a little head shopping to do it right, Aussie heads I'm sure are beyond his budget but some 2V Cleveland heads will do just fine and are around cheap enough.
Left to right, 351W, 2V Cleveland, 4V Cleveland.
400HP should be pretty easy, that's only one HP/CI. Yeah, the 335/Cleveland family doesn't have the support that the Windsor does. And no matter what building one is more expensive then a Windsor. But there is enough support now, pistons, manifolds, headers, etc. it's all out there at decent prices.
Steve, quadrajet really? There is an argument for spread bore, but Holley 4175.
  #33
Old 02-07-2015, 04:20 PM
BruteFord's Avatar
BruteFord
  #34
Old 02-07-2015, 06:05 PM
wtroger's Avatar
wtroger
wtroger is online now
If the truck is run loaded most of the time then go 460. Easy to get power out of them. A decent cam and pistons that get you close to 10:1 and you will be good to go. None of these get very good MPG. My truck weights 9100 lbs empty it runs real strong pulls good and and I regularly load it to 19,000 lbs and it still runs 70-75 mph with not much effort. Fuel mileage 8-10 mpg. 351W is a good motor just doesn't have the torque for a working truck
  #35
Old 02-07-2015, 06:23 PM
phoskins's Avatar
phoskins
phoskins is offline
If you get a 460, you'll need to upgrade springs & I don't know what else suspension-wise. I know a good 460 is hard to beat for power & durability.
I'd personally consider a well-built small block (351w), unless it will be used to haul and tow significant weight/mass most of the time. Good luck. I'm not brave enough w/vehicles to do an engine swap. I kinda envy you.
  #36
Old 02-07-2015, 06:31 PM
BruteFord's Avatar
BruteFord
If the truck is run loaded most of the time to the point that it needs a 460 then he needs a F250HD/F350 not an f150 with too much engine.
  #37
Old 02-07-2015, 06:57 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
it's extremely difficult to believe someones 460 truck can hit "teens" for MPG's with no lift and oem tires running empty 55MPH on the hwy non stop in ideal conditions.
i say this because we have loads and loads of 460 economy reports on this site.if you spend an hour looking up all you could find (perhaps 25-30? maybe 50 reports if you spend an hour) and averaged them all,it would be interesting to see.my guess it would be probably be 7 or 8.
when someone claims they can hit teens,with a lift and 37's....well im just saying your truck is in a tiny,tiny,tiny minority being able to compare with 351 economy of 12-13 hwy mpg (with no lift/oem tiers.)
i don't doubt you believe your odo/math but if you look into different mile measurements (gps/google maps) and perhaps do a consecutive 10 tank calculation,you might see different results.
f250/f350 diesel.
  #38
Old 02-07-2015, 07:24 PM
ponykilr's Avatar
ponykilr
ponykilr is offline
Difficult as it may be, it is true (on hwy). RCLB ZF5 with 4:10s. Keep it under 65 and don't drive it hard. I drive to New Bern NC, 165 miles round trip on 12.5 gallons. I am a 44 years old, I know how to do simple math.
This thread seems to agree with me.
https://www.ford-trucks.com/forums/1...s-mileage.html
  #39
Old 02-09-2015, 09:11 PM
steve33444's Avatar
steve33444
steve33444 is offline
I'm not expecting extremely great gas mileage cause I realize it's a truck..not a car. but what all would have to be done to fit a 460 in the truck? Would a mildly built 460 get about the same mileage as a mildly built 351W? Do you think it's worth it to do a 460 swap or would that be a waste of time/motor/money? Also is a 4 speed transmission good enough or should I get something like a zf5?
  #40
Old 02-09-2015, 09:23 PM
BruteFord's Avatar
BruteFord
Enough that unless there is a good reason to keep what you have you might as well just buy a truck with a 460. Better truck, cost half as much, take comparatively no time at all.
No worse.
IMO it's a waste.
If going 460 might as well get a ZF5.
  #41
Old 02-09-2015, 09:27 PM
steve33444's Avatar
steve33444
what if I went with a 351w? 4 or 5 speed? What kind or transmission?
  #42
Old 02-09-2015, 09:33 PM
BruteFord's Avatar
BruteFord
Depends on your use, budget, effort. Small pattern ZFs are harder to come by. M5ODs are common, cheaper, but not as good. Any freeway time? It's really about the OD and you'd only use that on the highway.
  #43
Old 02-09-2015, 09:56 PM
steve33444's Avatar
steve33444
I'm not sure if I want overdrive or not. I'm mainly on old back roads and off road so I don't think I need overdrive. Maybe a 4 speed with granny gear? Or do I not need the granny first gear? Did ford make a 5 speed with a granny 1st gear?
  #44
Old 02-09-2015, 09:59 PM
BruteFord's Avatar
BruteFord
I can't tell you what you want.
Yeah the ZF5
  #45
Old 02-09-2015, 10:01 PM
steve33444's Avatar
steve33444
I know but what would you get?
Yeah the ZF5
I thought the zf5 was just a regular 5 speed with overdrive?
Quick Reply: 351w vs 351m/400 vs 460?
