Help Me Understand H&S
So once I have the tuner, can I go ahead and install it on my truck right away or is there more to it? What is the unlock code and the MCC? Or do you have to get the unlock code and the MCC in order to delete? I am looking to delete that is all, no need for tons and tons of HP. As far as buying a used tuner, as long as it is not VIN married to another truck and it works, it should be good to go correct? I have had tuners in the past (on my 6.0 & Dodge) that came with canned tunes and that is what I'm used to. I do not understand what the MCC and unlock code does, or if you have to have it in order to delete. Can someone explain what I will need in order to delete? Nothing fancy I just want to get rid of the DPF. And from what I read I think I'm leaning towards the H&S XRT Pro. I currently have the Edge Insight CTS which I use to monitor things, which is why I don't think I need the Mini Maxx.
once you have the tuner go to there website and make sure its up to date with the current software version.- plug it into your truck and follow the on screen instructions
mcc tuning is custom tuning , not needed but optional (i don't use it personally yet)
unlock code is to make it work with the 6.7 power stroke, they said it took more effort to unlock the tuning on our model so they demand an extra $100 to unlock it
xrt pro is perfect if you have the edge to monitor.
all you need to start is a dpf delete pipe and tuner
be aware that you will not receive any customer service threw H&S if theres an issue down the road since they shut down they don't answer emails or there phone. you will need to contact a high end diesel performance shop/website that sells H&S
Because mine is a street tuner, MCC is how my custom "delete" tunes are loaded onto the tuner, and the unlock code has to be entered when installing the custom tune to the truck. To load the original street tune, all I had to do was plug in the MM to the OBDII and follow the prompts. Check YouTube. H&S used to have a series of videos on how to load tunes on the Mini-Max and get them into your truck.
I'm not very familiar with the handhelds, but I have read that you would need a vendor to set your VIN to the tuner to make it work as they are VIN specific (unless of course that is your VIN listed on the screen) - but please don't quote me on that as I am mostly familiar with the leave-in tuners. Wish I could help more, but I'm sure someone will be along tomorrow who is knowledgeable and will guide you in the right direction.
Hmm. Ok, I was under the thought that as long as it wasn't installed on another vehicle I would be able to install it on mine. Good to know.
Ok sorry re reading my post was confusing. As long as the tune was removed from the truck you CAN use it on your truck. Just make sure that the tune was removed from the previous truck and you should be good.
It gets complicated for a lot of people. It used to be if a H&S tuner (Race MM or XRT Pro) was tied to a 2011 or 2012 6.7L Powerstoke VIN, it was married to that vin unless you purchased another unlock code. It would not work with any other truck until another unlock code that is tied to the new trucks VIN was entered. Then the street tuners came out and you didn't need an unlock code. I'm not familiar with anything other than the original 109003 MM Race tuner and that needed an unlock code to work on a '11 or '12 Ford Powerstroke. If that XRT Pro Race Tuner for a '11 of '12, it needs an unlock code. Also, if it is a Race version, it will only work on an '11 or '12.
I'm certain that is incorrect for back when I did mine, but I'm not certain what Rudy's has done. I'd call them and ask them to explain why an unlock code is no longer needed. It is possible they are selling you a MM that no longer requires a code and it's as simple as that. It's been too long for me and a lot of things have changed. Good luck.
