R & R rear window??
should be a bolt in/bolt out. Be careful once the nuts are off (I think there are 9 around the inside under the trim), pry firmly but gently, you dont want to tweak the window and break something. As mentioned you will need a roll of the butyl caulking. Its kinda round, black and on a paper roll. I think I have seen it at autozone/advance. The hardest part is cleaning the truck and the new window for installation. That butyl stuff is a pain in the ***.
Wrong answer for the SE US if it makes any difference. Go see a Ford OEM replacement glass company that supplies Carlite glass. You will find they only replace an original Carlite rear window with a 1/4 inch black butyl tape seal. I would like to be corrected if anyone finds a different type of sealant used by and OEM supplier.
I supply OEM Carlite glass and it comes with 8mm M-seal. If you are given anything different you are dealing with a shop that is either misinformed or too cheap to carry the correct product
You are kidding, right. Remember you are in BC and I am in the Southeast US. What is an M seal. I would agree that 8mm is close to 1/4 inch. I am a retired Ford Glass Plant employee of 37 years but am always willing to learn.
M-Seal is for Modular window sealant. It is used in applications where an adhesive is not required. In the case of Fords modular or encapsulated windows, that are bolted in rather than glued in, a M-seal is used. This has a foam core wrapped in butyl to help keep integrity in the seal. If it was simply a full butyl kit it would eventually compress and start to ooze out much like you see on cars made in the 60's and 70's that had glass installed with butyl prior to the common and accepted use of urethane. I have purchased Carlite parts for 25 years and have worked on Ford vehicles assembled in many different plants and have never seen a Ford vehicle with a bolted in glass part have anything but a M-Seal kit.
Take if for what it's worth...If it was done at my shop it would be installed with a M-Seal kit.
A glass shop that knows their stuff should have it in stock, or at the very least, be able to order it from their glass supplier. If I knew how to load damn photo's on this site I could post a photo of what it looks like. You can PM me and I will give you my work email address and I can always email you a photo as well as the part numbers we use.
