To Delete or not...?
Got a new race mini maxx, unlocked with all the delete capabilities.
Have been running it with emissions on. And it runs real good. But still have regens at the most inconvenient times. And I just hate to stop in the middle on a regen and feel/smell the heat just radiating out from under the truck. Having to drive farther and longer than I want just to finish a regen is not my idea of a good system. Not to mention the hit mpg takes. JMO.
So for those of you that have removed just the dpf with a 'test pipe' and did not do a physical egr delete, but did unplug the egr, like the H&S MiniMaxx instructions recommend, is it possible to put the truck back to stock emissions and tune...? Will the ECU/PCM/BCM always keep a memory of the delete tune...?
I love this little MiniMaxx, its the bomb. Can only imagine how the truck will go and its mpg once deleted.
In all reality deleting the systems that historically have caused the most harm to the truck, can only cut down warranty work, as long as one runs a stock tune.
Probably just getting rid of that massive restriction in the exhaust will free up some torque/hp/mpg with just a oem tune. And relieving some heat build up and not recirculating the soot back into your engine, probably would seem to be good for the trucks longevity, yes...?
On the other hand I love the no smell diesel exhaust, and no black smoke. But during urea injection and regen there is a hideous smell that can't be healthy for anyone...?
How much smoke is there with the stock tune, all deleted, on a new 6.7...?
Ah, what is one to do...?
JMO
JMO
on
Well, if you're not out of warranty now, you will be as soon as you delete the truck...
Mine does not make any smell during regen that I can detect. Although I have not had to stop and shut down during a regen either...
Love the smoke free and less rattle of these newer trucks and it is so doggoned strong, I would find it hard to believe that I would need even more power..
About the only reason I could see to delete my truck would be to break free from DEF and to increase fuel economy..
JMO
JMO
yes, there is smoke, but depends on how hard you press the go pedal.
depends on the dealer whether you get hit with the tuner tracks..
some (used to) sell them as add on features, and support their customers.
take it someplace else (trouble on the road) and then have difficulties.
If you ran a 4" pipe to replace your DPF while keeping the stock resonator and tip, you could run stock delete tuning with your Low Boost Fueling to minimal and I think you'd be a happy man.
You wouldn't 'roll coal', but you could still make it puff depending how you loaded the fuel. Since your LBF would be minimal, your excess fuel (and odour) at idle would be minimal as well. Your EGR and urea tank could still be on the truck, with just a few plugs and a tune away from being stock.
I feel like you've already made the steps for the deleted world getting a Mini Maxx in the first place .
I deleted at 700kms and creeping up on 36000kms. I had a code thrown early on but it was false and solved by one of H&S' updates. No problems at all.
Thanks for all the replies guys, appreciate it. Its a tuff decision.
You mean like this pipe..? Think I'd be a happy man,, huh...lol. You might be right. Thinking about doing it, but then again, IDK...lol...?
stock tune ,low boost fueling at a 2 you will be fine. my main reason for deleting mine was because i drove around more trying to finish the regens.. annoying. I've had mine deleted since 13,000 miles and I've been to my dealer a few times for problems with stuff that they had to open the hood for. i never heard anything negative come from them about it. it pays to have a "guy on the inside" at a dealership. i made friends with a guy in the service department. not saying that helps me or not , but on a side note i did get to haul the 2 roush mustangs to the auto show in detroit when there 2015 super duty had there fuel pressure sensor fail on them.. bottom line is if you remove the dpf and disable the egr its and easy change back to stock if you need to for some reason just don't go beating on your rig IMO you have to pay to play if something happens under normal driving conditions then thats another story one to tell your dealer about
sct x4 i see a lot of guys running them pretty successful.
Waiting until this summer for my delete, letting the extended warranty expire. I have an H&S already, just need the pipe.
Is there any crackdown on roadside checks in the US? Up here the Ministry of Environment has cars on the highway and will write tickets for missing emissions equipment, something like 380$ per item removed.
