Seized 7.3?
#31
#32
Gotcha. Well I got everything put back together and started it up. Has a bit of greyish smoke coming out of the tail pipe and a lot of rough idling. I'm wondering if this has something to do with water in the fuel system? I heard that water in the fuel can cause surging and it often would surge when I was low on fuel or right after I would fill up. How would I go about checking this? I know there's a fuel/water separator but in the two years I've owned it I haven't touched it. Thoughts?
Thanks
Thanks
#33
#34
Thanks
Thanks
#35
#37
#39
#42
#43
You are right, Glenn's way will not work on the IDI. These have a 2 piece fuel filter, a replaceable upper filter, and a lower aluminum lower bowl that screw onto the upper filter. the lower bowl will have a **** that is connected to the drain screw,which is on the very bottom of the bowl. Turn the **** to open the drain screw. If it has been a while, get a new filter and change it, filling the filter with Powerservice diesel klean, or Howes diesel treatbefor installing the new filter. Then start it, let it run for 20-30 seconds then shut it off, and let it soak over night, then take it out and run it like you stole it. This will clean out the deposits from the injector pump, and injectors, and may smooth out your rough idle.
#44
I'll keep you posted, I appreciate it.
#45
Okay so I've replaced the filter, put in the fuel additive, and bled the valve when it was put back together. Absolutely NO CHANGE. I'm stumped, it must be something bigger. Or something smaller that I haven't thought of. I'm thinking of hauling it into the Diesel Specialist shop this week..
I've really appreciated all of the replies and insight. Anything else welcome of course! I'll keep y'all posted.
