How far do you have to go before your heater starts working?
Old 01-24-2015, 01:19 PM
Twitchyleprechaun's Avatar
Twitchyleprechaun
Twitchyleprechaun is offline
Originally Posted by Misky6.0
When the coolant reaches 100* the eatc system ramps up my fan and hot air comes out, until then I am thankful for heated seat and a jacket.
How far, depends on too many variables.
I don't start to feel heat until my temp is above 150°
Old 01-24-2015, 01:35 PM
hav24wheel's Avatar
hav24wheel
hav24wheel is offline
Originally Posted by EXv10
I don't think it it the mass but it is interesting that diesels take a long time.
That's because they have more coolant to heat up to reach operating temp...
Old 01-24-2015, 01:37 PM
hav24wheel's Avatar
hav24wheel
Originally Posted by Texas E
Fortunately we don't have it that bad here in Texas...
It all depends here. Like this week we are in the 40s.
But I usually let my vehicles warm up good in the winter before I drive them. I like to see coolant temps above 100 before I take off.
Old 01-24-2015, 02:00 PM
Tom's Avatar
Tom
Tom is offline
I don't think so. You can't heat up 60 lbs of coolant without also heating up 1,000 lbs of iron and steel. Heat goes from the cylinder to the block where it's picked up and circulated by the cooling system. That circulation evenly distributes the heat around the engine block until it gets warm enough to open the thermostat and bleed heat through the radiator.
It's a simple issue of mass and combustion. The V10 weighs around 600 lbs and has a less efficient combustion cycle than the 1,000 lb PSD. An extra two quarts of coolant doesn't make a darn bit of difference.
Old 01-24-2015, 03:30 PM
hav24wheel's Avatar
hav24wheel
Either way, there's more of everything to heat up on the Diesels. More oil, iron, and coolant. It's going to take longer.
Old 01-24-2015, 07:16 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
0 miles total no matter how cold out it is. Remote start, and let it run tell the windows are half thawed off.
Yup,
It's either in the garage, or i run that SOB until its toasty warm! I ain't getting in a cold truck.
Old 01-24-2015, 10:35 PM
EXv10's Avatar
EXv10
EXv10 is offline
Originally Posted by sessland
With the weather how it's been in the 7-14 range it takes between 5-10 miles in stop and go traffic for me to feel heat
That's too long, do you have the right thermostat?
Old 01-24-2015, 10:38 PM
EXv10's Avatar
EXv10
EXv10 is offline
How much more? And why is there more?................still doesn't sound right to me.
Old 01-24-2015, 10:41 PM
EXv10's Avatar
EXv10
EXv10 is offline
I agree.............again.
Old 01-24-2015, 10:46 PM
EXv10's Avatar
EXv10
EXv10 is offline
Originally Posted by AlaskanEx
Yup,
It always seems so ironic that you live in Alaska but hate being cold. I guess becoming homeless is never going to happen.
Old 01-25-2015, 12:07 PM
jamesbfishin's Avatar
jamesbfishin
jamesbfishin is offline
So wait, you don't agree its mass, and then later on another post you agree its mass. Lol ok
Old 01-25-2015, 12:28 PM
Magnus E's Avatar
Magnus E
Magnus E is offline
Diesels have higher thermal efficiency than gasoline engine (a higher percentage of the diesel is converted to work rather than heat). So there is less "waste" energy in form of heat that goes into the coolant. This is another reason it takes longer for diesels to heat up in addition to those already mentioned.
  #28
Old 01-25-2015, 08:23 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
now you got me interested. I don't think I've ever actually used the heater in my X...or my old 6.0 either
gonna check it out one morning this "winter"
  #29
Old 01-25-2015, 08:29 PM
05MilMachine's Avatar
05MilMachine
05MilMachine is offline
my truck runs at 185 on the obd2 scanner. It gets warm fast, but doesn't put out really hot heat until I hit the highway. Perhaps my stat has been changed in the past?
  #30
Old 01-25-2015, 09:16 PM
JTsEX's Avatar
JTsEX
JTsEX is offline
Here in the midwest, I love my V10. At -6, I can fire it up, punch the butt warmer and leave the heat off. By the time I've scraped the windshield the temp gauge has popped up. With front and rear blasting I can be in short sleeves and jeans in less than 5 miles. If a big gasser is taking forever to heat, might be a good time to have your coolant checked.
As a truck driver I can tell you a diesel isn't gonna get hot until it idles awhile. Best advise for PSD owners is let it get the oil circulated and go. Putting it under load is the only way to heat it up fast.
Quick Reply: How far do you have to go before your heater starts working?
