Polyurethane bushings and mounts ??
Old 01-30-2015, 01:32 AM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
I'm exactly about to replace that axle pivot bushings, as one basically exploded, any tips?.
  #32
Old 01-30-2015, 07:22 AM
351Cleveland C4's Avatar
351Cleveland C4
351Cleveland C4 is offline
Have a knife to carve out the old rubber. It's probably bonded to the beam.
  #33
Old 01-30-2015, 02:25 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
I'd still use a hole saw as I mentioned before. 1st one side of the oval and then the other side. It's OK to then use the hole saw as a reamer to clean all rubber out of the metal shell. The poly bushing is going to fit in that oval metal shell and not move. So if the I.D. of the metal shell ends up a little rough (not smooth) it won't wear out the poly bushing.
  #34
Old 01-30-2015, 02:39 PM
351Cleveland C4
I suppose another way that might work would be use a torch and burn the extra rubber out. But that has its own risks.
  #35
Old 01-30-2015, 03:16 PM
ultraranger's Avatar
ultraranger
ultraranger is offline
After I removed the steel sleeve from the pivot bushing on my '77 F100 front disc brake I beams, that I swapped into my '69 F100, I took the saw blade out of my hacksaw and inserted the blade through the hole in the bushing.
I reattached the hacksaw frame to the blade and made a cut downward through the rubber bushing, stopping just short of getting the blade into the thin metal bushing shell.
I made three more cuts into the bushing like this, 90° apart, to 'quarter' the rubber bushing. After I knocked the first quarter of the old bushing out, the other three quarters came out of the metal shell without too much fuss.
....least, that's how I did it.
  #36
Old 01-30-2015, 03:24 PM
CougarJohn's Avatar
CougarJohn
CougarJohn is offline
See Ranger above regarding poly bushings.
They squeak and will drive you nuts.
  #37
Old 01-30-2015, 03:47 PM
351Cleveland C4
Originally Posted by CougarJohn
See Ranger above regarding poly bushings. They squeak and will drive you nuts.
Mine haven't so much as chirped yet
  #38
Old 01-30-2015, 04:49 PM
crazed87bronco's Avatar
crazed87bronco
crazed87bronco is offline
Depending how worn out the bushings are. using the hole saw method is the easiest way IMO. the beams I just got the bushings were so worn I used a punch and knocked the inner sleeve out then took a chisel and pried the rubber piece right out.
  #39
Old 01-30-2015, 09:55 PM
instig8r63's Avatar
instig8r63
instig8r63 is online now
I blast them out in seconds with an air chisel.
  #40
Old 01-30-2015, 11:12 PM
351Cleveland C4
Very useful those things....
  #41
Old 02-01-2015, 01:19 AM
Encho's Avatar
Encho
Encho is offline
Can it be done with the arms still mounted? I haven't found many pics of this.
  #42
Old 02-01-2015, 07:28 AM
351Cleveland C4
Yeah, the radius arms don't have to come apart to do the pivot bushings.
  #43
Old 02-01-2015, 10:25 AM
instig8r63's Avatar
instig8r63
Pivots can be done in the truck. Blast out the old one with an air hammer and press the new one in using a nut & long bolt type press.
  #44
Old 02-28-2015, 11:28 AM
Encho's Avatar
Encho
Encho is offline
No power/air tools of any kind, I finally did the deed with the help of a local mechanic . He happened to be around working on a neighbor's car and I lent him some tools, so he pitied me and gave me a hand to take the bushing out of the arm (by BFH/chisel submission), which he recommended me to take off immediately, definitely the way to go.
  #45
Old 02-28-2015, 04:29 PM
Mister_King's Avatar
Mister_King
Mister_King is offline
Sway bars weren't standard equipment until dent sides?
Quick Reply: Polyurethane bushings and mounts ??
