I see alot of trucks on here with the Bully side steps. I have a 77.5 and would like to know if you had to fabricate a bracket or how you installed the steps. I need to get some and thought I would see what worked best for install.
thanks
Pic's would be great!
Are you referring to tube step rails or the "stirrup" step?
Like the Bully u shaped steps. I have read other threads, but nobody has posted pics of how they fab'd the steps in. There is no real step that you can buy out there with out mod's.
The little steps I've seen mount to the lip under the cab. I think that's a retarded way to mount them. When I decide how I want mine to look, they will go directly to the frame, I'm too big to put that much weight on thin metal. :P
