How to drill a leaf spring in less than 37 seconds!
Drilling holes in the overload leaf springs of your vehicle may seem like a daunting task, especially due to the characteristics of the hardened spring steel, however, we have a couple options for you.
Many factory overload springs are pre-drilled with 1/2” holes by the manufacturer, making installing a suspension upgrade like the StableLoads, a simple DIY experience. It is important to note that there are many applications of the StableLoad that do not require drilling. To check your application, click here.
If your vehicle does not have the hole pre-drilled, don’t panic or believe anyone who told you it can’t be done. Torklift engineers have contacted some of the world’s leading drill bit manufacturers that make specialized drill bits of all kinds as well as specialized hardened alloy applications. This includes drilling U.S. military armor plating. Based on their input we have the correct drill bits required and a few techniques that highlight the easiest way for anyone to drill a hole in a leaf spring.
There are two options using a common cordless drill. Drilling with our specially designed tool or drilling without, we will walk you through each technique.
Option One: How to drill with the Torklift International StableLoad Leaf Spring Drill Tool
What you will need:
Simply watch this brief video to see how it is done in 37 seconds:
The key to drilling a leaf spring effectively is to apply a significant amount of force, using a cordless drill with a very slow rotation speed and a well-lubricated drill bit. Using our special StableLoad Leaf Spring Drill Tool, cobalt drill bits and cordless drill, the specifically designed StableLoad Drill Tool cradles the drill allowing you to slowly guide the drill bit with little effort. No need to struggle with keeping the drill in place while applying a significant amount of force by hand -- the StableLoad Drill Tool does the work for you and is the simplest and quickest method to drill the spring.
If you have decided you do not want to use the StableLoad Drill Tool, visit Torklift's blog to see Option 2, a step-by-step technique on how to drill a leaf spring without the StableLoad Drill Tool.
What you will need:
- StableLoad Leaf Spring Drill Tool
- Cordless Drill
- Four 7/16” cobalt drill bits (These are included with your StableLoad suspension stabilizer)
- Cutting oil or motor oil to keep the drill bit lubricated during the drilling process
- 3/4" socket wrench
- Safety glasses
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
01-17-2017 04:59 PM
Torklift Sheryl
01-03-2017 07:14 PM
Torklift Sheryl
04-05-2016 02:49 PM
Torklift Sheryl
09-22-2015 05:02 PM
Torklift Sheryl
09-03-2015 04:23 PM
