f250 no power to cab
Tried to start my truck after sitting for 2 days in sub zero weather. wouldn't crank. pulled the batteries and charged them over night. Tried to start it the next day-wouldn't crank but the starter relay clicked. Was going to pull the starter and check it but decided to replace the relay first. replaced it and tried to start but now have no power to the cab-nothing comes on. I've checked the batteries with a load tester and they are ok. I've checked the fuses and they seem to be ok. when I tried to start it and the relay clicked there was a loud buzzing noise that seemed to be coming from under the dash. it has done this before but this time was louder than usual. I live out in the sticks so taking it somewhere is a last resort. any suggestion would be greatly appreciated. great site. It is a 1999 7.3 with 290000 miles. thanks
can't find any wires that aren't connected or appear to be damaged. there is 12.6v going to the starter solenoid. the only small wire I see is the that plugs into the starter relay. does the current run from the batteries through the starter to the fuse o in the engine compartment and then into the cab? thanks for the help.
If you put the feed for the power distribution box on the wrong starter relay terminal, not much will work right.
At the relay, there should be one heavy wire all by itself that goes to the starter, one small wire that goes to the small terminal, and everything else HAS to be connected to the relay stud that also has the wire from the battery(ies) positive terminal(s). That's the basic way the relay gets hooked up.
Made some progress in that now have power back to the cab and everything seems to be working. But now the engine cranks but won't start. This happen once before and turned out that the pcm was fried, had a chip in and it went south, expensive lesson. The service engine light came on a few weeks back so bought a scanner but it won't read diesel so for now I can't pull the codes. The batteries have been sitting out in the cool Montana nights so recharging them and see if that helps.
