Well captcaseyb I took your advice and decided to get some 15x10 cragar's. I'm glad I did, these wheels are killer. I decided to go with a 295/50r15. Haven't got the tires yet, but will soon.
Also as an update I installed the drop shackles and it looks much better, but still not 100% level.
A set of Moog 844 coil springs will raise the front about 1-2" and make it perfectly level
That's cool, post pics when ya get everything mounted.
" Then, years later I ended up cracking the driver front DJM I-Beam in half, "just by hitting a decent size pot hole." The DJM I-beam was made of cast aluminum with a steel tube inside.
They may have better products now.....I don't know.
Cast aluminum? Never known them to be made of alum. DJM Beams on mine with no problems.
I've been looking at these, I want a deep dish but I would like to tuck the wheel/tire inside the wheel wells, I'd like to drop it level sometime this year
