Brake MC pushrod adjustment?
Hey guys, Im using an 06 hydrboost and MC in a custom application, is the factory 06 SD brake pushrod adjustable some how? I need to shorten it about 1/4".
If not, is there a way to remove the pushrod from the unit without having to take the MC off the firewall? I will have to cut it, and sleeve it with some nice DOM tubing.
on
Use a bi-metal hole saw in a drill press, keep light pressure on it and lubricate with a light oil as you cut. I have done this with the same saws through hundreds of cuts in steel tubing as well as steel plate - all with the same saw... I may still have some spacers that were laser cut or done by myself. What is the hole spacing and what diameter center hole?
spikedog
01-23-2020 03:46 PM
