My new 79 F250
My new 79 F250
I finally got to see and drive my new truck I bought last May. It is a 79 F250 2WD Supercab. I was pretty excited to see it was almost exactly as the seller described. It runs great, drives down the highway like a dream.
A couple issues have been dealt with so far:
leaky master cylinder
leaky back sliding window
A few things need fixed:
the sun visor on the DS needs a new pin end (instead of the wood screw the PO used)
Tailgate has had a very poor bondo job done on it. Also PS rear quarter panel has a bad patch.
DS door panel has a couple screws through it and one crack needs repaired.
Power brake booster inop- feels like manual brakes.
Needs some matching wheels and tires.
Sliding window latch broke
Rearview mirror MIA.
Door bottoms need a little attention, as well as around roof seams, both have slight amount of rust starting to show.
So I picked up a divorced NP205 and a 1995 ball joint Dana 60 to convert this over to 4x4. I also have a 78 f250 (400 engine) 4x4 with a trashed body. I was planning to splice the front of the 78 4x4 frame onto my 79 supercab 4x2, use an adapter to mount the 460 /C6. I dont have both frames in the same location yet, so I can't really measure anything to compare.
Anybody see too many issues with this? I'm not sure if you can mount the TC shifter onto the 2wd C6. TIA
I was guessing I'd run the 95 springs, as they came with the axle. Either move the spring pads on the axle , or fab up some perches for the frame. Whichever looks easiest once I see all the parts at once. Do you have any experience which route is easiest?
My plans for the truck is not really for any extreme wheeling, so I dont have a need for these extreme suspension set ups that I see a lot of guys building.
The sun visor on the DS needs a new pin end (instead of the wood screw the PO used)
Sliding window latch broke.
So what else is new!
1973/79: F100/350 & misc Passenger Cars / 1975/91 Econoline / 1978/79 Bronco.
EOTZ-1040860-A (replaced D0TZ-1040860-A) .. Sliding Rear Window Latch / Available from Ford.
This has been a notorious POS since day one! It's plastic, has to be folded over upon itself to latch. Within a short time, the little charmer breaks in two.
Applications: 1970/96 F100/350 - 1997 F250/350.
D0AZ-17700-A .. Inside Day/Night Rear View Mirror / Black vinyl covered-Paint to match / 12" long x 2 1/2" wide / Reproduced by Carpenter.
Mirror glues to the windshield, since it's no longer there, might be found inside the glove box or under the seat.
Applications: 1970/91: F100/350 & misc Passenger Cars (LTD/Crown Vic/Grand Marquis and etc.) / 1975/91 Econoline / 1978/91 Bronco.
JTourney1
04-15-2019 10:56 AM
jay_blu
11-20-2014 10:15 AM
kevin316
35
09-25-2012 10:25 PM
STGFordCrazy04
11-12-2006 10:18 PM
