1972 400M - Possible Carburetion Issue?
Old 01-01-2015, 05:04 AM
Spktyr's Avatar
Spktyr
Spktyr is offline
Posting here for a friend because he's not able to find much of any other support online for his car and the majority of surviving 400Ms are in trucks, so people here would know about them.
The car in question is a 400M powered 1972 Ford Country Sedan station wagon (think stripped Country Squire and you have the idea). It has just 46,000 miles or so on it. The stock 2 barrel and intake were immediately removed when he purchased it ~6000 miles ago and replaced with an Edelbrock Performer 400 intake manifold and a locally rebuilt Carter AFB 625 4bbl carb. The points were replaced with a Mallory 61002M points replacement system. Otherwise the car is mechanically stock; it was filled with Shell Rotella T 15W40 oil before it left.
The carb was overhauled, installed and tuned by a competent mechanic in Joplin, MO. It was then taken on a multi-thousand mile US road trip during the month of October before being shipped to my friend's home country of Germany where during the process of adapting it to local regulations, the carb was adjusted by a local Berlin mechanic using an exhaust gas analyzer as it was thought to be running a touch rich (and European fuel prices being what they are, that's not a small concern.)
His problem is that after this adjustment, the car seems to be lacking power and consuming more fuel in certain regimes than it was in the US.
While he was driving it here:
Ambient temps between 50 and 75F
Interstate driving, average 75mph indicated, '13-ish' MPG
Highway driving, average '50ish' mph indicated, '14-14.5' MPG
City driving, average '30ish' mph indicated with stop and go, '10-11' MPG
Car had torque everywhere and didn't seem to struggle.
Over in Berlin, post 'adjustment':
Ambient temps between 23F and 50F
Interstate driving, average 75mph indicated, 11.5 MPG
Highway driving, average '50ish' mph indicated, 9.5 MPG
City driving, average '30ish' mph indicated, 8 MPG at best, often 7MPG or worse. (His Berlin 'city driving' has been just four to six mile hops so it's likely that the choke's still on and affecting the fuel economy that way.)
Some of his comments on how the car is behaving:
Additionally, Dan fumbled something up while re-tuning the carb and Lucille's drinking spiralled out of control to the point where I consider renaming her Harald: While the drop to 11.5 mpg highway might be down to my newfound confidence to driving her more spirited on the better tires, 7-ish mpg in city driving are just wholly unacceptable.
Dan says he tuned her slightly leaner, as per the lambda readings. I feel she might be a bit down on power as well
Sooo... anyone have any idea what this setup *should* look like on an exhaust gas analyzer in terms of air fuel ratio? Should he just start over with default settings and work on settings from there? While we know his settings are now messed up, should there be this big a drop in fuel economy with a drop in temperatures like this? Any help would be appreciated.
Old 01-02-2015, 06:27 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
Ok, this is what typically happens.....
in a perfect world, with the air/fuel mixture set according to the "meter", on flat ground, typical ordinary driving, yes, it will run fine & get better mileage. Now for the real world, with carbs, they really need to be set (in most cases) slightly rich....this provides better accel which means less throttle typically used and ie better mileage, etc.
59pan
33
10-22-2020 11:28 PM
RomerB2
Alternative Fuels, Hybrids & Mileage
84
04-08-2019 11:31 AM
Davidvc1964
1999 to 2016 Super Duty
20
07-05-2013 02:59 PM
DIYMechanic
47
05-09-2012 11:57 PM
olfordsnstone
12-02-2006 01:30 AM
Quick Reply: 1972 400M - Possible Carburetion Issue?
