1974 F100 in Germany - Questions over questions
Old 12-16-2014, 04:08 PM
benbuilder's Avatar
benbuilder
benbuilder is online now
As Zark-Eh said, maybe the printed circuit is bad or dirty. I have read a lot of posts where owners have cleaned up the copper circuit board where the lights plug into It with an eraser. I tried that with not much luck. I started out with no lights also. I was successful with some steel wool and a wire brush. I cleaned each bulb, socket pins, and the circuit board with the wire. When I put them back in, they all worked. Might be the answer?
Old 12-16-2014, 04:11 PM
thatsrealnice's Avatar
thatsrealnice
thatsrealnice is offline
Originally Posted by TheGermanGuy
ok, got it - at least the Emblems are in good shape
Guten tag. I'm curious to know if the German laws pertaining to old cars are as stringent as I've heard. A friend told me that basically any modifications to the car at all, makes the car not eligible to be on the roads on Germany. What has your experience been so far?
I can't imagine filling up one of these trucks in liters. My 78 has dual tanks, and when gas was higher, it was over 100 bucks to fill both tanks.
Maybe when you get a chance, you can upload some pictures of it. Must be quite a sight, and I'm sure it gets lots of looks.
Old 12-16-2014, 04:14 PM
TheGermanGuy's Avatar
TheGermanGuy
TheGermanGuy is offline
ND that was just an attempt to assist you in military installation locations. Being that you have never served in the military, how would you ever know, unless you google it?
I haven't understand this and hardly understand all your figgures of speech. "Got it" meant -> No Camper Special
Old 12-16-2014, 04:17 PM
thatsrealnice
ND = Numbers Dummy. They are joking around with each other
Old 12-16-2014, 04:19 PM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Moderator & parts seller
Received 3,288 Likes on 2,444 Posts
Sorry OP (OP='s Original Poster, that mean YOU) to semi high jack your thread with a side conservation with ND='s Number Dummy.
Old 12-16-2014, 04:25 PM
TheGermanGuy
Oh yes! Laws are quite stringent. But the guys don't know much about Ford Trucks and so they overlooked the Edelbrock Intake and the Manifolds and rated it with a "Classic Car Certificate" what means 99% original and in above average good shape.
To be honest, I haven't seen one like this over here for 6-7 years! Later models and chevys are not so hard to see because Friedberg Army Base was just a few km from my home and US Forces are still in Gießen (40km).
Old 12-16-2014, 04:33 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
How do you know I never served in the military? In fact...I have a VA card because: #597-15-69 USN 1962.
Here's some more parts catalog pics for your collection: Left/Right (upper): Fuses / Left (lower): Bulbs.
Old 12-16-2014, 04:34 PM
TheGermanGuy
Thanks! I'll check all that when swaping the Speedo from Mph to Mph+km/h. And I found the High Beam Switch a few minutes ago. Must appear mad to you: Finally paid triple of what the truck costs in US without knowing how to switch to High Beam
Old 12-16-2014, 06:01 PM
thatsrealnice
Don't feel bad. I hadn't had my truck very long, and I had shifted the transfer case into Neutral, and then when I went to drive it, it just sat there. I kept thinking something in the transmission had broken, and someone on here mentioned the transfer case. I felt really silly.
Old 12-16-2014, 06:26 PM
77&79F250's Avatar
77&79F250
My bad, you just sounded like you had no experience with military installations in Germany....which I now understand, you being in the Navy way back then would more than likely have no reason to have experience in that country.
Are you a Pollywog or a Shellback by chance? lol
NOT that being in the Navy or being either of the above is a bad thing at all. Truce ok?
Old 12-17-2014, 08:30 AM
NumberDummy
Truce ok?
Si, como no.
The thing is, I have many other interests besides vehicles. I'm a USN, Maritime & Military historian covering the years 1865-1945.
WWII: First, I read about the PTO for 20 years, then switched to the ETO in the 1970's. I've made it a point since I retired, to visit many sites in the Pacific & European Theaters.
Old 12-23-2014, 12:01 PM
TheGermanGuy
Hi all. Thanks for all the infomations! I took off the Dash Bezel and managed to pull the intrument cluster. (Found great hint for "disassembling" the main light switch in another thread here!) Unfortunately all the instrument bulbs are ok and cleaning the circuit connectors didn't help. And while it's not enough to find nothing faulty, the white plastic housing of the intrument cluster is crumbling apart and needs be replaced...
Does anyone know where I can get just the plastic housing for a few bucks? Dont need instruments at all...
For the first I would like to check the cluster illumination itself. Does anyone know where I have to connect 12V to "turn the lights on"? Ho can I check the Voltage regulator?
Dome light in my truck is not working, because bulb and bulb socket are missing, so I'm looking for the socket as well... 12V Voltage is there when door is open...
EDIT:Just figured out that the dome light bulb has two wire loops those wo getting hooked over the two pins I've seen. So there is no "socket" for the bulb. Bulb type should be "Rigid Loop Socket #562, 13.5V, 10 W, 0.74 AMP, T3" right?
  #28
Old 12-23-2014, 03:53 PM
77&79F250's Avatar
77&79F250
Instrument cluster only, LMC item #12. Lots of other vendors carry this part, but usually more $, but better quality too.
Truck Parts and Truck Accessories
Dome light wiring help, read on its in here.
https://www.ford-trucks.com/forums/1...then-some.html
Dome light....
http://www.lmctruck.com/icatalog/fc/full.aspx?Page=155
http://www.lmctruck.com/icatalog/fc/full.aspx?Page=69
  #29
Old 12-23-2014, 05:30 PM
thatsrealnice
You might check some forums such as this but for European car clubs. I'm sure others have imported these era trucks, or Econoline vans. Also some of the European Ford products might have had similar clusters during that time, might check any automobile salvage yards around there as well. You never know what might be available.
  #30
Old 12-23-2014, 05:37 PM
77&79F250's Avatar
77&79F250
Quick Reply: 1974 F100 in Germany - Questions over questions
