Not quite broke down in TX/AZ - map sensor???
This may or may not help, but I had the same problem with my truck a few years back...it ended up being the pin on the PCM that carries the MAP signal. When I attached the bulk head connector at the firewall to the PCM the pin got bent provideing an intemittant connection. I straightened it with a pair of needle nose pliers and all has been good.
It's all internal to the little motor in the door lock actuators.
Same as the aluminum-foil "fix", but you tin-snip a penny to the same size as the varistor, and plug it in place of it.
See: https://www.ford-trucks.com/forums/4...cks-fixed.html
Just did the Turner and Will Rogers last month, and the tolls aren't all-that-bad. Unless, of course, you are spending NOTHING at all on fuel!
Pop
Pop
Jason good thing you are driving by yourself after the Del Taco.
#30
