brake light switch
brake light switch
good day all have a 2014 f250 gas engine that i was playing around under the dash and blew a fuse no dash lights or engine start. found a defective fuse on the passenger fuse box changed it engine starts now but no brake lights and cant get vehicle out of park. is there a fuse somewhere for the brake switch ? if not how can i test to see if this is the problem. thanks
If you need to move the vehicle while searching for the fuse/brake light problem turn the ignition key to the first detent before the dash is energized. This will keep the shift interlock from activating so you can shift into neutral, start and drive the vehicle. Anytime you shift back into park you will have to go through the same procedure until the brake switch is operative.
