No power in overdrive
Hey guys, hope you can help me out. I have a 93 f250 351 auto with 1.5 dual exhaust and 31x10.5 tires. The truck is seriously lacking power when on the highway. It constantly kicks in and out of overdrive to maintain speed. If I'm driving into a wind it cannot hold 60-65 on flat ground without downshifting out of OD. What I've done so far is plugs, wires, cap, rotor, air filter, fuel filter. Also checked compression and it only has a 8 psi different across the motor. Any help will be greatly appreciated. Let me know if there is any info needed that I left out. Thnx!
Welcome to FTE!
I would assume you have an E4OD transmission. I assume you have 3.55 gearing. I do know that my wife's 2000 Expedition with the 5.4 and 3.55 or 3.73 gears with same trans or 4r70w does the same. Also, my 302, .40 over, 31-255-5 Comp Cam, 3.55 gearing and AOD trans does the same. I have same tires as you and my tires are larger than the Expedition.
All in all, it sounds about right. I always keep the truck and Expedition in "D" when there is large amount of headwind.
May not be the best answer, but it seems normal. Hopefully other members will share their thoughts.
Maybe it is just fine and I'm overreacting, but I find it somewhat hard to believe. I've had 2 other trucks of this generation and I also have a bronco and none of them are dogs like this one is. Any slight incline and it loses mph as if I've let off the gas. If the answer is to not use OD the I'll be doing around 2500 rim just to do 60....
A lot depends on if you know everything about the vehicle. And you said compression test is good on all cylinders. New exhaust, so that takes care of notoriously clogged cats. Fuel psi to spec? Rear drums perhaps dragging a bit? Have you checked for stored codes?
Just some more ideas.
I saw the 1.5 exhaust, but I think it's a typo too. That would be a large bottleneck.
