Project 'Off Duty' - 1984 F150
Old 12-03-2014, 10:12 PM
4x484150's Avatar
4x484150
4x484150 is offline
Smile Project 'Off Duty' - 1984 F150
Howdy folks,
I'm back to yet another planning stage of what my ideal vision for my truck is. This time, I want to plan out exactly what I want to do, one section at a time.
My ultimate goal is to restore it, but finances and family are more important right now. The truck will basically be for fun on-road, I don't have any good spots around me for off-roading.
So on to what I'd like to do:
Current setup:
1971 302, with E7TE heads
NP435, mated NP208
8.8 rear
Ideal setup:
351W, stoked to 408, possibly get Thumper to work on the heads, or get aluminum ones
ZF5 4x4, keep my NP208 for simplicity, and to keep cost down
Keep my 8.8
Exhaust, brake lines, fuel lines, things of that nature will be replaced with stainless steel, and any regular steel will be removed of rust, and POR-15 applied.
Users on FTE in no particular order, have inspired me to be meticulous on my trucks restoration: Luke76, Gary Lewis, 1980 Ford F-250, Piston Honda, Ranger 350, and displacement4me.
Old 12-04-2014, 06:34 AM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
That's a good goal, and one that can be done incrementally. But, you should figure out what your plans are for the heads before you start the engine build. That's because you can, and should, run more compression with aluminum heads than with iron. The aluminum steals heat from the combustion such that you need to run almost a full point more compression to achieve the same results. That requires different pistons or smaller combustion chambers, or both. So it is good to know the plan before starting.
As for the tranny, the ZF5 can be done later as well. However, the small-block ZF's use an integral hydraulic slave cylinder so you will have to run a hydro clutch linkage. Your '84 probably already is hydro, but even if it is it may not have the reinforcement plate on the firewall, which I highly recommend. These firewalls were not designed for the forces a hydro clutch brings and Ford learned that early on with major problems with cracked firewalls.
Old 12-04-2014, 08:06 AM
reamer's Avatar
reamer
reamer is offline
Don't forget the small block ZF is 1 inch longer that the NP435, = rear shaft 1 " shorter, front shaft 1" longer, (to be in spec)
Old 12-04-2014, 07:06 PM
4x484150's Avatar
4x484150
4x484150 is offline
Gary, for the heads, would you go aluminum, or keep the iron? I know there are pros and cons to each. Personally, I'm leaning towards keeping the heads I have, as it will save me some cash.
Now, the ZF5, I was planning on finding one to swap in before I decide to get a 351w. I've been researching the caveats of that swap. My truck is indeed a hydraulic setup, and have Terrapin Manufacturing in mind.
reamer, thanks for that information, I have not found that bit in my research. I would imagine that the drive shafts ought to come from an 88-96 F250/F350 single cab long bed to match the distances?
Old 12-04-2014, 08:32 PM
reamer's Avatar
reamer
reamer is offline
I have a small block ZF sitting on my bench now, (make sure it's for a smallblock).Try to get the tranny hump floor cover too, it is higher that the one for the NP. I plan on cutting/lengthening my original shafts
Old 12-04-2014, 08:37 PM
4x484150's Avatar
4x484150
4x484150 is offline
I found several small block ZFs near me. I wonder if I cant find a small block truck tranny cover, can I use a big block/diesel truck's cover?
By the way, how far into the swap are you?
Old 12-04-2014, 09:42 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
The question on the heads depends on what you want to do with the truck. Iron is cheaper, but by the time you have them worked they won't be a bunch cheaper. So do the math and see if extra punch and MPG beats the extra cost. I did that and went with aluminum.
Old 12-05-2014, 09:00 AM
reamer's Avatar
reamer
reamer is offline
Get the cover from the ZF donor truck, Not sure about a BB cover on a SB tranny.
Swap will not be till next spring, I want to get mileage data with the NP 435 first and wait till it blows-up or leaks more. But since they are hard to find around here, I got this one from a running truck for $350.
Old 12-05-2014, 09:13 AM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
IIRC, there is only one floor cover for the ZF, regardless of engine.
Old 12-05-2014, 12:19 PM
reamer's Avatar
reamer
reamer is offline
Well then, good to know!
Old 12-05-2014, 05:57 PM
4x484150's Avatar
4x484150
4x484150 is offline
For the engine, Im looking for something with more oomph, but not a high performance engine.
The transmissions I found are from Car-Part.com--Used Auto Parts Market, so I dont know if the trucks are there as well. I have a favorite yard near me that I know the owner real well, and he loves Fords too, so he always gets them in. I should be able to get one of these(taken from Fordzilla80's build thread)
Is this what you were refering to Gary?
Old 12-05-2014, 06:05 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
I think that's the one. However, it confuses me as it has a hole for only the t-case shift lever and not the transmission. So it can't be for a ZF5. However, it has the step-up. Anyway, you want one that steps up like that.
Old 12-05-2014, 06:21 PM
4x484150's Avatar
4x484150
4x484150 is offline
This one is Shaun's automatic inspection cover, thats why its a bit confusing.
Old 12-05-2014, 08:07 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Oh. Duh! You said that.
Old 12-09-2014, 06:16 PM
4x484150's Avatar
4x484150
4x484150 is offline
I was thinking about this the other day, even though I still want to get a ZF tranny cover, I dont have to get one right off, as I have a 3" body lift, right?
Quick Reply: Project 'Off Duty' - 1984 F150
