1995 F350 7.3 died mid drive and has trouble starting
I just recently traded for a 1995 F350 7.3L with 259,000 miles on it.. I immediately noticed a problem when I would go up a steep hill and the check engine light would come on and it would lose power.. Shortly after that the check engine light turned off and the truck died on me.. I let it sit and cool off a little, then had to use a little starting fluid to get it back running again.. It has trouble starting when it's hot or cold, it'll just crank but won't fire at all.. I'm new to the diesel world so I'm clueless on what it could be.. Any help would be greatly appreciated !!! Thank you !!!
I traded on Monday.. The guy didn't have it long but he never changed the oil but it has enough oil, it has a oil leak and the guy would just add oil to it without changing the filter.. I plan on servicing it today.. And when it starts up I see some blackish/grayish colored smoke come out the tail pipe
Sounds like the PO (or perhaps several PO's back....) just kept topping up the oil, thinking that constitutes "changing" it. Bad idea with any engine, since it can't magically leak/burn only the oid oil, there's ALWAYS going to be some VERY old oil in the engine using that method. Goes doubly so with an engine that relies on consistent quality engine oil under pretty high hydraulic pressure to run.
F350-6's smoke question was about whether it smokes when it CRANKS, but does NOT start. (Or when it cranks before starting.) That bit of info helps to narrow down the no-start (or hard-start) possibilities.
damonlan
1999 to 2016 Super Duty
06-12-2017 08:46 AM
erkeene
02-01-2016 04:25 PM
shawn.mcdevitt
12-03-2014 11:46 PM
quality1construction
79
03-03-2008 08:12 PM
