1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Map lights, visor mirror light & rear map lights not working?
Old 11-27-2014, 01:51 PM
brkncly's Avatar
brkncly
brkncly is offline
So my driver side map light went out, went and replace the lamp. Now I can't turn on the map light when I depress the lens on both front map lights. Both rear map lights don't work either when I flip the switch and the driver or passenger visor mirror doesn't turn on when I flip the mirror cover. Maps lights do come on when I open doors. Also my Home Link (garage door opener now doesn't work). It's throwing a P1260 code (Theft detected vehicle immobilized). Does anyone know if this might be related to my light issue? Is there a fuse on relay that controls this that might be bad or something needs to be reset? I've looked at the fuses by the passenger floorboard and every thing looks good. Please anybody? Happy Thanksgiving & thank you! Any one have any idea why this is happening? Any help would greatly be appreciated. Thanks!
Old 11-28-2014, 08:15 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
It helps if you tell us specifically what you're working on.
The overhead courtesy light is separate from the map lights, they just happen to be in the same enclosure.
chocolatechip3512
01-09-2024 02:21 PM
Johnny Battles
Modular V8 (4.6L, 5.4L)
09-09-2015 06:13 PM
boaterdude83
1997 - 2003 F150
09-17-2008 01:17 AM
wagntwister
04-15-2008 01:32 PM
5.0EBExplorer96Snow
12-22-2004 11:35 PM
Quick Reply: Map lights, visor mirror light & rear map lights not working?
