Diesel repair prices?
I recently got a quote for some repairs to my 2000 F-250, 7.3. Do these seem like fair prices?
Parts-
Mr. Bobs CAC Air Kit - 357.00
Down Tube Gasket (2)- 40.54
Down Tube right- 59.41
Down Tube left- 73.12
Exhaust adaptor behind turbo- 162.28
UVC connector- 93.48
Valve cover gasket- 128.33
Injector- 318.95
Diesel fuel additive- 18.52
Applied wastegate- 160.00
Total parts- 1,411.63
Labor for all- 822.90
Total cost- $2,347.46
Parts-
Injector- 318.95
well since you have a 7.3 there is no valve cover gasket the ucv harness is the gasket in most cases they are all one package and no most of those prices dont seem good, most of the repairs you have listed can be done with simple hand tools, and ive never actually seen the mr bobs kit before
here is the UCV
DORMAN Valve Cover Gasket Kit 615-201
here is the UCV
Can I ask what was happening with your truck with the need for the repairs? To Me it sounds like the down pipes, most of us call them up pipes, do not replace them unless they are replaced with bellowed up pipes. Riffraff diesel has heavy duty cac hoses very reasonable ( at half the price) Uvc connectors usually come with the fel-pro aftermarket uvc gasket. look them up on line at the nationwide chain parts stores. Injector is high, Got my NEW STOCK ALLIANT injectors Not rebuilt for approx 220 per injector from Clay at RiffRaff. Not sure on adapter behind turbo aka exhaust back pressure valve, or the wastegate actuator. It will help if you post this on the 7.3 forum. Oh and the addative seems high unless there is a fairy good quantity.
Parts-
CAC Air Kit 357.00 $128 Complete CAC Intercooler Boot Kit 99-03 - Riffraff Diesel Performance
Down Tube Gasket (2)- 40.54 included
Down Tube right- 59.41 included
Down Tube left- 73.12 included
Exhaust adaptor behind turbo- 162.28 $419 International Bellowed Stainless Up-pipe Kit 99.5-03 - Riffraff Diesel Performance
UVC connector- 93.48 $43.79 Under Valve Cover Harness 99-03 - Riffraff Diesel Performance
Valve cover gasket- 128.33 $59.81 Valve Cover Gasket 99-03 - Riffraff Diesel Performance
Injector- 318.95 $219.96 Alliant 'AD' Injector - Riffraff Diesel Performance
Diesel fuel additive- 18.52 $17.45 REV-X Distance+ Diesel Fuel Additive - Riffraff Diesel Performance
Applied wastegate- 160.00 $176.45 Turbosmart Performance Wastegate Actuator - Riffraff Diesel Performance
Total parts- 1,411.63 $1064.15
Parts-
6BTJames
11-22-2012 09:08 AM
