1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
'05 F250 5.4 multiple codes
Old 11-24-2014, 09:42 PM
Ky. Super-Duty's Avatar
Ky. Super-Duty
Ky. Super-Duty is offline
My 2005 F250 started missing about a week or so ago, it gets worse when the engine is warm. I took it and got the engine codes today, it has several misfire codes; P0300, P0301, P0303, P0307 and also has a P0174 (fuel system lean bank 2) and a P0430 (Catalyst system efficiency below threshold) I can't afford to start throwing money at it and I really need to get it going ASAP, any advice on a fix or even a starting point would be greatly appreciated.
Old 11-25-2014, 07:42 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
How many miles?
Any service history, like new spark plugs or coils or such?
Old 11-25-2014, 08:18 PM
Ky. Super-Duty
162,000 miles on the truck, I have had it for only a little over a year. I have not replaced anything or had any kind of trouble until now. I don't have any information or service records before I bought the truck.
Old 11-26-2014, 06:46 AM
hodge5's Avatar
hodge5
hodge5 is offline
Chances are, the codes are all related. Did you do a google search on them, referencing the year and model truck? Quite often, a simple google search with the codes will point you in a direction of someone who has had, and worked through, a similar issue.
Old 11-26-2014, 08:13 AM
projectSHO89
A google search will probably just waste time and cause confusion.
You have three separate types of fault codes:
1. Misfires on both banks plus a random (unable to identify) misfire code.
2. Mixture control bank 2.
3. Cat efficiency fault bank 2.
Don't know if you checked for pending codes, but that would be a good thing to also do if you haven't yet done so.
There's a very good chance that the faults on bank 2 are interrelated. Bank 1, not so much.
I'd start with some basics:
1. Check intake system for vacuum leaks, especially in the PCV system. Vacuum leaks can cause "lean" codes, misfires, and resulting skewed fuel trims that can damage a converter or can cause false converter efficiency codes.
2. Reset the PCM and allow the faults to re-occur and get a fresh set of codes. You may have a set of codes that have accumulated over time and are clouding a more specific code or code combination.
3. Check fuel pressure to verify proper fuel supply. The symptoms of a weak fuel supply can mimic those of a vacuum leak.
Old 11-27-2014, 08:16 PM
Ky. Super-Duty
Thank you for the advice, I'll get the codes reset and check these things out as soon as I can and I'll post what I find.
Belgar
Modular V8 (4.6L, 5.4L)
01-10-2015 08:14 PM
Truckie256
03-18-2014 12:29 AM
88f150302
1997 - 2003 F150
12-14-2010 11:43 AM
1977ford250
04-15-2010 09:15 AM
Quick Reply: '05 F250 5.4 multiple codes
