Transmission fluid capacity
I'm guessing your transmission is a C-6 (?). If so, 7 quarts of type F transmission fluid.
If you're having to fill the torque converter too, about another 3.5 to 4 quarts.
Products that 'seal' leaks just have additives that swell the seals up. This is a band-aid fix. The only right way to fix a leak(s) is to replace the leaking seal(s).
You probably don't want to hear that since it's a lot less effort to pour some snake oil down the filler tube but, if you want to fix the problem and fix it right....
Thanks!
AlaskanEx
20
09-25-2020 08:14 AM
lonelypauly
10-02-2012 09:04 AM
todd_adams2001
17
09-22-2003 09:08 PM
