1998 Explorer transmission seal coming off
Hi..Have 1998 Explorer with 5R55E tranny and the automatic transmission extension housing seal keeps coming off, allowing a fluid leak. I just replaced it and it's doing it again. When I put it in there, it seemed tight, but...any ideas on how to keep this thing in there?
Most unusual complaint. If it seems to fit the extension housing tightly, I might ask whether you were able to de-oil the inner surface completely, or at all? Most seals have a coating on their outside diameter which adheres to the housing, if it's not wet with oil, and helps seal also.
So long as it's the correct seal, I would try what I suggest above. The oil must be stopped from leaking in order to clean the housing with solvent. This can be done by raising the rear of the truck fairly high to keep oil from draining out. Otherwise, drain the transmission partially, first. impish
pc09123
1983 - 2012 Ranger & B-Series
06-12-2009 08:05 AM
MrV300xlt
06-05-2003 10:04 AM
wickware
01-19-2002 07:45 AM
