Body parts compatibility.
The doors are all the same 1980-1996, as far as the sheet metal goes, but you need a 1992 and up with the chopped wing window though... or it will not clear the OBS dash. Electric vs manual controls are also a consideration as far as how easy the swap goes but RC/SC/CC makes no difference.
on
i had a '96 years ago.there is an extra seam at the bottom of the door.i dunno if '97HD had those or not.92-95 should? all be the same,be it any of the cab configs?
i would search and then ask here to verify:
https://www.ford-trucks.com/forums/forum28/
I did a little more checking, and the only sheetmetal difference 1980-1994 is different types of mirror mounts. 1995-1996 had two variants, one with and one without the lower body line. However there is NO difference between standard cab, super cab, crew cab and full size Bronco. They all use the same front doors.
Jmerchant6_9
07-06-2018 01:29 AM
JackErnie
03-31-2014 01:24 PM
