1951 Early F2
#33
There should be a spring behind the escutcheon. Press down on the escutcheon until you see a pin that is installed in the handle. Drive that pin out with a drift.
I used to do this all the time with early VWs. My interior panels are gone, but I'm other members have direct experience with our trucks.
Am I right, or am I just blowing hot air? Please chime in.
#34
Yeeeup,, just push the center of them round duhickies in,,, spring loaded, and locate the round pin and push it through. I used a nail that is smaller in diameter than the pin.
Putting them back on is a breeze if you pre-load the pin in the handle, just enough to still allow the handle to slide on. Once they match up just push the pin on in...
......Roger
......Roger
david schmidt
35
03-04-2015 10:49 AM
C.batchelder
05-13-2008 11:56 PM
mr4speedford
18
09-30-2003 08:19 PM
