Trouble starting in 35 degree weather
So before I wasn't hearing a click from the GPR. so I crossed the 2 postes with a screwdriver and turned the key to wait to start and I heard a click from the GPR took the screwdriver off and BANG fires right up!!! And I shut it off let it sit for like 5 min and let it cool done. This time I didn't have the screwdriver on it. I heard the click from the GPR and turned the key and it fired right up!! So I'll try it again tomorrow morning and see if she fires. Thanks for your help!!
Hey bro, this will help you with your GRP.
It will be the last GPR you will have to buy for a while.
There are write-ups on the mod, but here it is, the Stancor GPR
http://www.dieselorings.com (purchase)
and Welcome to guzzle's White-Rodgers (Stancor) GPR replacement Mod Web Page (Write up)
P/N STANCOR relay #586-902.
If you don't believe me, just look at all the threads on it!
I'm sure there are other places you can buy the relay, but this should plant the seed.
And I never go anywhere without tools!
Well... So i thought it was all good... I tested the plugs by puting a voltage meter on the pins. And I only have 2 working. So is the glow plug really bad or is it a connecter that's sending a false reading?
And I was looking for a glow plugs and I couldn't find a part number. The one I found on fords motor craft site I couldn't find any where else.
Were you measuring the resistance of the glow plugs, at the UVCH connectors on the valve covers, with the harnesses disconnected? If so, what resistance readings did you get? If not, then you didn't test the glow plugs.
iwas measuring the continuity of the plugs. The one was 8.5 and the other was like 4.5 and the rest where 0.
