As bought pics of my '50 F6
The 2 speed rear had two options for ratios; really low and even lower still (5.83/8.11 or 6.33/8.81). No matter how big your engine is, your top speed will be limited by the final drive gearing. But if you're planning on working it, the 390 will be a much better choice than the 302. Finding a 10.25" Sterling rear from a later truck to swap in will provide much better gearing with heavy duty strength for work.
For 1950, the trucks had a choice of blue paint colors:
Alpine Blue
Barcelona Blue
Sheridan Blue and
Strata Blue
1950 Color Codes - Ford Paint Cross-Reference
The only one I'm familiar with is Sheridan Blue.
Alpine Blue
Barcelona Blue
Sheridan Blue and
Strata Blue
Edit: One other reason is I am favoring going to an automatic because my left knee is not what it used to be and working a clutch can be aggravating, to say the least (reminds me that I am getting older, I guess). Since I have been taking glucosamine it has troubled me a lot less, but it has just started getting cold here and so it is beginning to give me more problems.
Last edited by Sportster.Mark; 11-17-2014 at 12:23 PM. Reason: Made additional comment
This is a good robust unit. See link. Expensive, yes. You still have the torque converter slippage if you go with a C6. I went with a 700R4 for the lock up feature along with OD.
https://www.gearvendors.com/
Thanks Ray. Pricey it is, but it looks like a solid unit. I don't think it is within my price range, at least not on the income I have right now, unless I manage to sell off some of my accumulated spare parts. I found an adaptor to mate a E4OD or a 4R100 to an FE here:
Transmission Adapter Pricing
I bit pricey but nowhere near the price of a separate OD unit. Can either of these be run without a computer control?
That is next on the agenda after I get the wheels all straightened out. In fact, the drivetrain and the brakes are what I have been putting the most thought into. For example, right now the e-brake is attached to the output shaft of the 4sp, and when I swap in a C6 I am not yet sure how I will make an e-brake work. Does anyone know if there are later parts that I can swap into my 2sp rear to give it an e-brake?
There is no provisions to put an e-brake on the rear
Stock rear has double anchor shoes
#29
Okay, for the drivetrain I guess I will stay with a standard transmission. I found a 5sp that came out of an older Ford bus (that is all the info I have on it, that and it has an e-brake attached to the output and a handle that looks identical to the one I have in the F6 right now). I am going to pick it up tomorrow and I'll know what model it is then. When I know, I'l post here what I have.
#30
Here's the one going under the Studebaker. Stu
