Out of town with white smoke
I've been reading that you need to what your truck for white smoke religiously. When I started my truck this morning I noticed a puff of white smoke. After going to the store no more smoke. I watched the exhaust the entire way. I've been monitoring my numbers and nothing out of the ordinary. I'm 300 miles away from home should I be concerned?
I also have a little puking after opening the hood two streaks on the degas bottle. It also act like it wanted to go dead at first almost like a stutter then it ran fine. Then other day it was first thing in the morning on start up it started idling high like I had an high idle mod and then went back down. I just don't want it to sit down on me on the way back home.
Ok so that explains the high idle. It was 33 degrees out that day. Ok so when I first got the truck the degas bottle had no signs of puking. Drove it on a 309 mile trip and it puked on the trip. I wasn't towing anything cruising at 70-75 I seen a high delta of 17 but 14-15 was most of the trip and I was getting a under boost code. Took it to powerstroke help in Buford, GA. They cleaned the turbo and checked the EBP and said the unison was sticking, and changed the degas cap. Got back from that trip took it to the dealership had the coolant, power steering fluid flushed, oil change, and fuel filters changed. This was in July. Three weeks ago I put in the mishimoto 200 degree t-stat filled her back up to the min level and haven't had any problems until this morning when I noticed the white smoke and spotted the puking.
When I bought my truck it was puking a little but deltas were always perfect. The cap seemed to be a little worn so I replaced it and it's been fine for over 15,000 miles.
That could very well be your white puff of smoke; if the cylinder wasn't hot enough...it won't light the fuel off until compression heat takes over. The glow plugs help the cylinders light the fuel off until the engine warms up; the colder it is...the longer they stay on. And in the case of the 6.0L the longer the glow plugs are on...the longer until the alternator starts charging the electrical system. Thus, allot of short trips in cold weather are a really bad idea with this engine.
Since your degas cap has recently been changed, I feel it's safe to rule that out. Might be a good idea to put the truck nose down (rear end 4-5 inches higher) and pull the EGR valve and see if you've got coolant there. Not saying it will be there...but it won't hurt to check.
As it continues to cool off, your going to notice that white puff getting worse. I'd look into getting that glow plug replaced.
